Question about Olympus Camedia C-3030 Zoom Digital Camera
Don't have driver for olympus c-3030 zoom camera
  • 10,421 Answers
beergut707
  • 79 Answers
SOURCE: driver software to load my olympus c-920 zoom 1.3mp
Hi there
Connect the camera
Turn it on
Open (my) computer
Look for a hard drive which wasn’t there before
double click it
Inside there will be several folders
One of them has your pics in it
Copy and paste them to wherever you want
Hope this helps
Beergut707
Posted on Oct 28, 2008
  • 11967 Answers
SOURCE: Olympus 760 . Zoom wont retract camera/it is fully charged?
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 09, 2010
  • 102366 Answers
SOURCE: i have olympus camedia
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Posted on Oct 22, 2010
muntejaya
  • 10421 Answers
SOURCE: vista driver for olympus c-3000 zoom digital camer...
Please get here then : www.olympusamerica.com > Home > Support www.olympus.co.jp/en/.../digicamera/qa/.../di000400e.cfm Regards
Posted on Feb 08, 2011
  • 102366 Answers
SOURCE: i need windows 7 driver
Consider NOT using a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Jul 01, 2011
Cant find the cd to install the software for my c-3030 digital camera. can you help
You can find the software for the Olympus Camedia C-3030 Zoom HERE.
But if you need only the software, you might want to have the newer and
also free Olympus Viewer 2 software.
Aug 12, 2011 | Olympus Camedia C-3030 Zoom Digital Camera
Need C-3030ZOOM Software download Not RadioShack add
Here you go....you can download the required software for your Olympus Camedia C-3030 Zoom Digital Camera;
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=521
Jan 23, 2009 | Olympus Camedia C-3030 Zoom Digital Camera
Hardware
problem driver xp driver web page driver noooooooo i whant driver olympus c-3030 xp driver
my e-mail adres
john007silver@hotmail.com
pls send
Oct 19, 2007 | Olympus Camedia C-3030 Zoom Digital Camera
Conversion lens
A conversion lens should be attached using the conversion adapter CLA-1 (41mm-43mm, optional) and the step-up ring. However, the fish-eye conversion lens FCON-02 cannot be used
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Batteries
You will be able to shoot approximately 300-400 frames with the LB-01 Lithium batteries, under normal use. Battery life widely varies depending on the type of battery, manufacturer, camera use conditions, etc.
Metering systems
The C-3030 Zoom has two metering systems: the Digital ESP metering system and the Spot metering system. In the Digital ESP metering system, the center and periphery of the picture composition are separately measured to select the optimal exposure. In the spot metering system, only the center is measured. Therefore, a darker subject can be taken with proper exposure without being affected by backlight, etc.
Connect an external flash
For external flash use with the C-3030 Zoom, you will need the appropriate flash cable and grip. Please use the following as a reference: Exclusive Grip FL-BK01 - used to mount external flash to the C-3030/C-3000 Bracket Cable FL-CB01 - this cable is required for the dedicated FL-40 flash PC Flash Cable FL-CB04 - this cable is required for any "other" external flash/strobe use that connects with PC sync cable
Olympus Camedia C-3030 Zoom Digital Camera Logo
230 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
