Question about Troy Garden
Troy bilt gas trimmer gas lines broke and now I'm not sure which lines go where.
    President:
  • Troy Master
  • 1,545 Answers
The gas lines probably broke because of the ethanol-laced gasoline we have to use nowadays. It deteriorates them. If the unit has the external purge/primer bulb, the way mine did, it is not that hard. Just remember...the primer bulb "pulls" fresh fuel from the fuel tank to and thru the carb, thus pushing out any air/old fuel in the metering chamber of the carb back to the fuel tank in the return line...that said..
Fuel tank...2 lines...smaller diameter line goes directly to the carb body. There are probably 2 brass nipples on the carb. This line goes to the one on the body opposite the end of the carb with the vent-hole in the cover. This is the fuel pump end...where fresh gas enters the carb.
The larger line out of the fuel tank connects to the longer nipple on the purge/primer bulb. This is the fuel return line.
The remaining fuel line (larger diameter) goes from the vented-cover (has writing on it) end of the carb to the shorter nipple on the purge/primer bulb. This line carrys air and old fuel OUT of the carb to the bulb where it is then PUSHED back to the fuel tank via the return line...so you have a small diameter supply line to carb...an intermediate larger diameter line from the carb to the bulb and finally the larger diameter return line from the bulb BACK to the fuel tank.
Go to a small engine shop and purchase about a foot each of the 2 different diameter fuel lines needed and install those new "Tygon" fuel lines as your fuel line replacement.
Posted on Jul 10, 2010
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
How do i fix my flooded TB32 EC troy bilt weed eater?
be sure fuel filter is on the primary fuel line in the tank.check primer bulb and fuel lines.also check fuel tank cap.vented cap may be stopped up
Sep 10, 2012 | M T D Southwest Inc Troy-Bilt TB32EC...
Replace duel string trimmer line
Change the line on Troy Bilt 4cycle TB525EC weed eater
Oct 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My Troy-Bilt line trimmer model no. TB539E Line trimmer disintergrated while using it. My problem is finding and ordering replcement parts and if necessary how to install them.
Several small engine dealers have parts for Troy Bilt but here is one site that will give you your part numbers and an idea of the costs you are looking at. Good luck!
http://www.ereplacementparts.com/
Aug 17, 2010 | Troy Bilt 17 Inch 29 Cc Gas Powered...
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Ive got a troy-bilt gas trimmer tb25cs it has always ran perfect,until now when i start it up aqnd give it gas it stops running and leaks gas
Check and clean your spark arrestor located behind a diverter plate on outside of muffler. You'll need a #25 Torx, or one slot screwdriver and wrench to take the plate off. Clean it with carb cleaner and wire brush and re-install. If this screen gets clogged, it could lead to fuel spray coming out of carb throat. Clean and re-oil the sponge filter while you're at it. Hope it helps!
Mar 24, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
How do I get an Owners Manual for Troy-Bilt Line Trimmer TB70SS
I googled tb70ss manual and the first site on the list showed a manual for your line trimmer. It is in a pdf format.
Good Day.
Nov 18, 2009 | Troy Bilt Tb70ss Gas Trimmer
Trimmer will not start.
Yes. Your carbeurator is gummed up. Get some new gasoiline and add some carbeurator cleaner to it, usually one ounce per gallon. Dump the fuel u have in there and put in the new fuel.
Also, get some spray carb. cleaner, remove the air filter and put a couple of squirts into the air intake chamber. Then start it.
Finally if it still won't start, use a squirt of starter fluid to get things going and get the carbeurator cleaning into the system.
May 20, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
408 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
