Question about Whirlpool WGD9500TC Front Load All-in-One Washer / Dryer
Won't start & it locks for a long period of time
All of a sudden it seems every load i put in (not heavy loads either) the screen shows the words "sud" or "F 35", even if i adjust the load amount.
    President:
  • 1,382 Answers
F35 error indicates Analog Pressure Sensor Failure. If this failure is displayed, there is a malfunction in the steamer component detected by the Steamer Electronic Board.
Please check for the following to solve this issue
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Thank you !!
Posted on Jul 09, 2010
Trying to start Lenovo laptop but just the "Lenovo" word shows up & nothing happens
Try to remove your hard drive. The company I work for uses mainly lenovo laptops and we have found if a hard drive goes faulty it will hang at this LENOVO screen. if you remove it and it progresses to the bios (it won't load windows since the hard drive is not in the laptop) you might need to consider replacing the hard drive and reinstalling windows.
Oct 07, 2014 | Lenovo Computers & Internet
What is the wattage draw for an AIR V unit, my 4000/3500 generator seems to load out and will not start the compressor !
A generator must be able to put out the locked rotor amps listed on unit in order for it to start . Locked rotor is usually 4 to 5 times the normal run amps .
Sep 28, 2014 | Heating & Cooling
LG WD1470FD won't open
You will need to replace the door lock assembly. If remove the top, you can reach down and manually open the door. Below is a video to show you how to replace the lock. Here is the lock to order.
Dec 04, 2012 | Washing Machines
My camera stopped working on my phone. Is there any way to fix it?
i don't know how to get a free video handler to my phone
Dec 26, 2011 | Sanyo SCP-2700 Cell Phone
Have fed pacific 100 amp main [rh13100 na ni ] that gets hot when ac,washer&dryer are all on,just started to trip main ?
Rich, This may sound obvious, but either the main breaker is acting normally because the load is near 100 amps, or it's defective. If it seems that the loading conditions have not changed from prior years, then you have probably been close to the 100 amp level before and a small amount of corrosion has occurred over time (accelerated by the heavy loading). The cleanliness and tightness of connections is critical to carrying loads at rated capacity. If you are close to the rated load, then replacing the main will buy you some time (but probably not as much as the original because the bus bar connection to the main is probably slightly corroded too) but it won't solve the problem - you will need to upgrade to a higher amp service. On the other hand, if you can calculate or measure the total load and you aren't near 100 Amps, then you just need to replace the main. One other thought. If you have a significant part of the load that is not 220V, then it you might have a higher load on one phase than the other, and could possibly be remedied by switching phases on some of the branch circuits. You only have to exceed 50 amps on one phase to trip a 100 amp main. Good luck, Al K
Apr 12, 2011 | Your One Source 100 Amp Main Breaker
Final spin cycle I get sud error code or f2, water mostly drained but no spin. When I restart the spin cycle just starts to spin then stops, sounds like it drains some more water then makes a small...
Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer won't spin unless you help it get started
Replace the brake on the transmission shaft. It is binding. While you have it torn down replace the direct drive coupling also.
Aug 22, 2009 | Kenmore Washing Machines
Whirlpool WGD9500TC Front Load All-in-One Washer / Dryer Logo
Sal De
Gerry Harvey
Gerry Harvey
