Question about Speed Queen AWS17NW Top Load Washer
My Speed Queen Commercial Dryer has broken the plastic dial switch. This has happened because the screw to turn the machine on and off is hard to pull. I have tried to loosen it with WD40 I am now using pliers to pull the screw. I live on a Pacific Island so there are no repair men except me, I can import a part. Please any help is appreciated Anne
    President:
  • 1,554 Answers
The part simply needs to be replaced. Please indicate the exact model number of the dryer for the correct replacement parts. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from posting comments or follow-up questions. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
Posted on Jul 09, 2010
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
I have a Hotpoint WDF740 washer dryer. When I turn the dial it doesn't register any cycle it doesn't make any noise when the dial is turned, therefore I can't use the machine at all. Can this...
This just happened to my hotpoint washing machine, I realise it has been a long time since this has been asked but since my answer is different from the others I thought I'd add it anyway in the hope it will be useful to someone one day. The fix was super easy, all that was wrong was the plastic knob itself, which had broken internally. I only found this out after taking the top and front covers off, which is an easy enough procedure, I did it this way: unplugged the washing machine, removed two screws from back of machine that hold top cover in place, then using a putty knife pushed between the top and front covers front to back right at the corners, thus releasing the top cover, once this was out I could unclip the front cover and get to the screws that hold the control board to the front cover. I unplugged the electrical connection to the board, removed all the screws and unclipped it from its plastic cover. At this point I could see the plastic knob had broken, I recovered the broken bit and glued it back on. After the glue dried, I just put everything back in place reverting the previous actions. Hope this helps. If you don't have glue or can't find the broken piece, you should be able to just buy another plastic knob off the internet.
Jul 06, 2011 | Hotpoint Aquarius WD640 Front Load...
I have a speed queen electric dryer model number aem45300. problem the dryer runs but does not heat. We cleaned out all the area that contained lint. Is there a reset button for the heating element in...
There is no reset button, check yoru breaker, by turning FULLY OFF (somewhat forcefully off) then back on and test again.
All thermal limiters will auto reset when cooled...
Mar 04, 2011 | Speed Queen AES17AWF Electric Dryer
Dryer tumbler continuously rolling.
you have a broken door switch,open the door and click the little paddle that's there,if it doesn't click most likely it's bad,when you open the door the door switch clicks open and kills the power,your switch isn't doing this.i tried looking up your model number to give you the part number but it didn't come up
Apr 01, 2010 | Dryers
My speed queen gas dryer drum will not tumble what do you think is wrong?
Most likely the drive belt is broken. If you pop off the panel at the bottom of the machine, you will probably find a broken belt on the inside. The belt itself isn't very expensive and the overall repair is around $75 to have a repairman out.
Apr 15, 2009 | Speed Queen AGS28AWF Gas Dryer
Speed Queen AWS17NW Top Load Washer Logo
Top Speed Washing Machines Experts
Dan Webster
Dan Webster
Coss
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
