Question about Home
Constant water dripping out of shower spout - Home
  • osevgi Jul 09, 2010
    water dripping out spout in shower
  • Anonymous Mar 17, 2014
    constant drip of water through shower head.( aqualiser mixer )
    President:
  • 670 Answers
The problem lies with the shower spout faucet. Is your shower controlled by seperate hot and cold faucet or by a single control knob. If it is the old type of dual faucet, the problem could be a worn washer or valve seat. If it is a newer type of control knob then, a new cartridge may be needed. I can't give you much more help without more information about your situation. Can you give more details about the shower setup. Thanks, Hope this helps.
Posted on Jul 09, 2010
    Brigadier General:
  • 3,917 Answers
Hi
Please check this links for your query
http://www.ehow.com/video_117462_repair-tub-shower.html
http://www.boston.com/yourlife/home/articles/2006/06/01/fixing_a_leaky_tub_shower_brilliant_ideas_for_a_shed_door/
http://www.diydoctor.org.uk/projects/leaking_shower_or_bath.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
2 Suggested Answers
r_b03
  • 102 Answers
SOURCE: Grohe shower head about 12
Hi!yes you can do-it your own.You must have some tools to remove the valve then you can replace it by your self.
Posted on Aug 24, 2011
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Constant drip
there may be some debris caught in the cartridge's,got push'ed in when water was turned back on.take apart and look in the brass valve body to see if any thing is in there.flush it out before you re-assemble it.take a good look at the cartridge,make sure there is no scuff mark's or any deformities.
Apr 26, 2010 | Moen & One Handle Tub & Shower Faucet
When I push the faucet to off I get med fast
push down the tub-spout lift rod and it will empty the remaining water that is between the shower valve and the tub spout
Mar 10, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
Feb 28, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
New moen one handle shower faucet drips
sound's like you either have some debris caught up in there, or you might not have your handle on correctly. give that a try .
Jan 23, 2010 | Moen & One Handle Tub & Shower Faucet
Water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Jun 14, 2009 | Water Pik WATERPIK SHOWER HEAD COMBO PACK...
Dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
Home Logo
242 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
