Question about Frigidaire FAX054P7A Wall/Window Air Conditioner
Water Do you need to put water into the AC unit? If you do where does it go?
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. No there is no need to put water in the air conditioner. You will get condensation in the unit from the humidity in the air condensing on the evaporater coil.
Posted on Jul 09, 2010
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
WATER DRAINING UNDER LEFT FRONT...other than that it works fine
The window unit needs to have a god tilt on it aiming it outside,and remove the unit and clean the unit out with a water hose ,make sure the bottom of the ac unit has all the debris removed.
Jul 31, 2011 | Haier ESA3109 WallWindow Air Conditioner
Brand new GE room size ac unit (1 week old) is spiiting water out of the air vent into the room. Unit 100% level.
If a brand new unit is spitting water, i waould suggest that it is short of refrigerant... Get your installer back or the Manufacturer.. You need to hold An ARC licence to do this ( In Australia)
Jul 16, 2011 | Heating & Cooling
Where do i put the water in? i have a ge stand up ac
If its a AC unit, you add no water. If its a humidifier you add water, but you do not want humidity this time of year.
Jul 03, 2011 | GE APH10AA Air Conditioner
My ac throws water back into the house when running to long, water builds and does not leak out of unit,do i need to drill a hole on the bottom of unit and if so where is compressor so i dont puncture it.
sounds like your condensate drain is stopping up or not draining properly. I would check and make sure the unit's drain is open and water is draining.
Also it's possible that the AC itself needs to be tilted (just slightly back in order for the water to drain better. Sometimes people will make sure the unit is installed perfectly level for cosmetic purposes not realizing that the water needs to drain out the back of the AC.
good luck!
May 04, 2010 | Sharp AF-S120FX Air Conditioner
Our de-humidifier is running cool but there is no water in the bucket, should there be?
Is it warm outside,and do you have your A.C. on? Dehumidifiers ,just like A.C. systems, remove humidity. If the weather is cold, put an open gallon of water in front of your unit and let it run a day or so. If the bucket gets water in it, and the container of water goes down, then the unit is working.
Feb 22, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Having my air ac 6000btu gold star driping on inside floorwhat is it
the AC unit is not level. the ac should sit level front to back... if it is leaning into the room even at the tinyest pitch, the water will run into the room. the ac should NOT be tilted backwards either, they need to sit level. take it out, and put it back in...
Aug 02, 2009 | Goldstar Heating & Cooling
New AC unit mist
It sounds like the unit is either level or tilted down in the front, not allowing the water to run to the back of the ac and the blower wheel is picking the water up and blowing it into the room.
You need to put a level on it and lower the back of the ac so the water the coil removes can run to the back of the unit and that should solve your problem.
Jun 07, 2009 | Friedrich WallMaster WS10B30 Air...
Water leak on passenger side on 99 chevy s 10 not anterfreeze, leaks when not being driven
there is only one thing that leaks water there, that is the AC condensation drain, water forms as part of the AC cooling the evaporator core, this water must be drained away or it will flood onto passenger area, so there is a drain on the passenger side at bottom of firewall, will leak allot of water depending on how humid the air is.
May 05, 2009 | 1999 Chevrolet S-10 Pickup
A.C. unit
One of the cause of water dripping in the indoor is restricted drainage. To Identify if your drainage is restricted.
- Turn "off " the circuit breaker and take out the face cover of the unit.
- Turn "on" the circuit breaker and start the unit, wait until the unit drips.
- When the unit dripped check the drain pan if overflowed with water.
- If the drain pan is full of water you need to flush the drainage with water to remove the restriction. If the pressure of water in your area is high you can use your garden hose to flush the drainage.
Another is dirty evaporator fins (icing), dirty drain pan, broken drain pan or incorrect installation.
YOU CAN LOCATE THE DRAINAGE AT THE LEFT OR RIGHT SIDE OF THE DRAIN PAN
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
Frigidaire FAX054P7A Wall/Window Air Conditioner Logo
94 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
