Question about Toshiba Satellite A45-S150 Notebook
Reformating the hard drive
The recovery (from a CD) process failed at a write error. Since the recovery process only does a "quick format", I guess if I can do a normal format of the hard drive, then the recovery process may go through. But how do I force the recovery process to perform a normal format of the hard drive? Are there other ways to force-format the built-in hard drive?
  • 3 more comments
  • chenxinghao Apr 19, 2008
    The recovery process starts with deletting (files on the C drive, I guess) followed by a quick format, then showing the percentage of copying recovery files. Other than the warning in the beginning and the chooice of C for continue or A for abort, no other options are given.
    I am having trouble to copy the DOS boot disk (3.5 floppy) to a CD - once the boot disk is in a desktop floppy drive and the folder is open, the floppy drive just keep spining non-stop.
    The Toshiba A45-S150 can be setup to boot from the CD drive. The original OS is a Windows 98 SE, with a recovery CD.
    The CD drive is working fine, I think, because it reads the recovery CD during the process until a write error comes up at around 25-30% in the process.
    My guess is that the internal hard drive has bad bits and bytes and a normal reformat may get to skip them.
    I guess I will need the SYSTEM BOOT, FDISK, and FORMAT files on a CD disk in order to boot the laptop and format the HD. But I have not been able to copy these files to a CD disk on my desktop, which has a floppy drive and a CD-RW drive, running Windows-XP (doesn't have a recovery CD or a stand-alone XP CD).
    Thank you all for the good suggestions. Thr problem is that I have not been able to get a bootable CD disk with the mentioned disk ultilities on it.
    Does the win98 bootable CD have the mentioned ultilities on it?
    OK. Made the win98 bootable CD and placed it in the CD drive. However, when the laptop is booting from the CD drive, the screen shows the following lines:
    Intel (R) Boot Agent FE v4.1.10
    Copyright (C) 1997-2003. Intel Corporation
    PXE-E61: Media test failure, check cable
    PXE-M0F: Exiting Intel Boot Agent.
    The first two lines will also appear when using the original recovery CD and it would go to the file copying process until a write error takes place. So the CD drive is fine.
    I guess the win98 bootable CD iso is not recoganized by this Toshiba A45-S150 laptop which was previousely installed with Windows 98 SE.
    yes, F12 gives 5 options to boot from. I chose the CD drive boot.
  • 111 Answers
Just simply use a ordinary XP cd installer and you will have an option to delete all partitions and reformat the HDD (not quickformat). But normally errors like what you got there is caused by Bad cd or cd drive.
Hope this helps.
Posted on Apr 19, 2008
    Genius:
  • 1,027 Answers
Any partition software can format the hard drive,
I use powermax/maxblast by maxtor/ seagate
Super FDISK works
Partition magic
My favorite is GParted Live cd.
gparted will id all partitions on the hard drive, allow you to re-size them and format them any way you want. Particularly great if there is a recovery partion that is "hidden"
  • 1 more comment
  • Mark Williams
    Mark Williams Apr 19, 2008
    But then I always like using Linux to fix Windows.
  • Mark Williams
    This link is for a win98 bootable CD .ISO with cdrom support
  • Mark Williams
    It still sounds like it is trying to boot from network not cdrom
    if you boot and press f-12 do you get boot options?
    Genius:
  • 3,587 Answers
High level format should appear as an option from recovery cd..
Can i use samsung recovery solution 4 for reformating the samsung n150plus?
Yes you can and if you just want to format the hard disk the discontinue the recovery installation.
You can also use a Windows installation Cd to delete the partition on the hard drive, create a new partition and format the partition then do not continue with the Windows installation.
Apr 03, 2012 | Samsung N150 (36725723009) Netbook
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Micro sd 2gb tidak bisa format
Hallo scorpio, semoga solusi ini membantu
If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
Hi i loackd my memory card few mnths ago and nw i forgot the password i tried diffrnt paswrds but its stil locked,,,n it gvs option of formating it but i dont want to loose my images vdos n muzik...kindly...
Memory card in a locked condition, the data can be saved. There are two ways you can do:
1. Use the data recovery software (must be software full version). How: insert memory card, run the data recovery process, select the drive memory card, etc. Save the file to your hard drive recovery. After the data saved, memory card format (quick format), then restore the data into the memory card.
2. Quick format memory card, and do the data recovery process. So that data can be saved, do not do a full format, but do a quick format. Tools such as hard drives, flash drives, memory cards, when done quick format, data can be saved.
Sep 24, 2011 | SanDisk 2GB microSD Memory Card
My toshiba 1 tb hard drive all ofa suddn says that i need to format it and i have alot for stuff on it that i need how can i make it work again
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 28, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
I have toshiba cavino 750gb hard drive. it was working fine since last night i can't open it.. it takes long time to open and i see format to paly it i don't want to loose my file i need some...
Don't be panic. you can try some format recovery software. You can see
Aug 03, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
I Have WD Passport Hard Drive in Side More Data But I Will Connect the HD Ask Format? How Can I Recover My Data Pls Help Me
Apr 28, 2011 | Western Digital WD Passport 250GB Portable...
When running the recovery wizard I get to cd 3 and while in the finalize process I get an error "error occurred at final process of recovery?. This is the third attempt. Help please
Sounds like the recovery CDs might be bad. Too bad you don't get a message a little more specific. There might be several methods of recovery--have you told it to do a complete recovery (formatting the hard drive)?
Oct 24, 2010 | Sony VAIO PCG-K25 Notebook
Reformated used HP recovery disc when I restart it says SW build ID different from ID on recovery media
You have 2 options. You can write to Microsoft or to HP about your Issue & they might be able to help about the ID issue. Best I would suggest you buy the OS. ( Full installation Pack) this way you have nothing to worry.
May 11, 2009 | HP Pavilion a1610n PC Desktop
Needs reformated
Most probably you will have to format the disk ... since the partion might have lost from the .. thumb drive..
so use some kind of recovery tools to get the data bak from your drive ...
there is a lot of recovery tools in Hiren's Boot Cd ...
Nov 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Toshiba Satellite A45-S150 Notebook Logo
305 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
