Question about Harman Kardon AVR 300 Receiver
Device code for HK 300 for Remote programming?
QuantumFx REM-300 programing guide
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Mar 13, 2016 | Televison & Video
How to program
Jumbo remotes are basically the same, regardless of the name on them. Assuming you do not have a copy of the code list, begin by turning ON the device you want to control. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button. Press and immediately release the desired mode (device) button. The red indicator will blink once. Aim the remote directly at the device you wish to control and press the ON/OFF button repeatedly (up to 300 times!) until the device changes channel. The red indicator blinks off with each button press. When the device changes channel, press the ENTER button. Programming is much easier using direct entry of the code.
Oct 02, 2014 | Innovage Jumbo Remote Control
Lost programing instructions and codes
1. turn on device
2. press setup (underneath on/off) till red light stays on the take finger off the button
3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once
4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press
5. press and release enter to install code
3-Digits Universal Remote Codes
4-Digits Universal Remote Codes
GE #24912 Universal Remote Instructions
GE Universal Remote Instructions
Apr 15, 2011 | GE JASRM24912 Remote Control
I lost the codes to the remote and i need to find them
There are two ways to program the remote. http://www.jascoproducts.com/support/universal-Remote-codes.asp has the code lists (for the above model look at the 4-digit code list). The other way to program the remote is: turn on the device you want the remote to control. Press and hold the Setup button until the red indicator lights up. Then press the device (TV, DVD) button quickly - the indicator should blink off once. Next press the On/Off button repeatedly until the device turns off (up to 300 times). Press and release Enter to save the code.
Please note that if the device was built after the remote was programmed (or in the ~6 months before the remote was released), the codes for that manufacturer may not work.
I hope this helps.
Aug 25, 2010 | GE JASRM24912 Remote Control
I lost my remote control codes
Hi! For me to give you the codes for your GE remote control is first I need to know the type and brand of device you want to be programmed to your remote control. Since you did not indicate the information I need I suggest that you try these steps for you to program your remote control without the code list.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired device button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the ON-OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
5. Press and release ENTER to install the code.
Jun 14, 2010 | GE JASRM24912 Remote Control
I have lost the ge universal remote guide for the codes its a ge sku 24914 universal remote i need the codes to program the remote
These are the steps on how to program your GE Universal Remote Control without the list of codes.
1. Manually turn on the device to be
controlled.
3. Press and quickly release the desired device button. The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
Note: Code Search starts from the currently stored four digit number under that mode. Sometimes the
first code that “works” with your device may only
allow limited functionality (e.g. the MENU button
might not work). There may be a code that performs
more functions. Continue the code search process
until the best code is found.
Jun 13, 2010 | Universal Remote Control GE174Universal...
Remote control CODES
HOW TO PROGRAM GE JASRM24912 Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on then take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code.
Hope this works for you
Sep 15, 2008 | GE JASRM24912 Remote Control
Ge universal remote
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
Sep 06, 2008 | GE JASRM24912 Remote Control
How to program my rav 300 remote
Here's how I got mine to work. FIRST THING: Once it's programmed, you use the TV function keys at the bottom of the remote for Power On, channel changing, etc. The other keys on the remote don't operate the TV.
1) Press the "code set" button with a pen or straightened paper clip
2) Press the [A] key (next to "V-AUX")
3) Enter the code
Test it by pressing the Power key in the TV section on the remote (NOT the "Source" Power" key or Main power key at the top).
Jan 10, 2008 | Yamaha RAV-300 Remote Control
Need the RAV-300 Remote Control Setting Steps
RAV311 WJ40930 US
(1) To program the remote to control a TV, press and hold [TV] for at least 5 seconds. To program the remote to control any other device, press and hold [AV] and the desired input button, (i.e. Press and hold [AV] + (DVD) at the same time for 5 seconds for a DVD player.
(2) Enter the 4 digit code for the device
Hope this helps.
Jan 08, 2008 | Yamaha RAV-300 Remote Control
Harman Kardon AVR 300 Receiver Logo
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
