Question about Nikon Speedlight SB-600 TTL Flash
Flash working inproperly
I am having a problem with my sb 600. My flash does the weird battery thing, I put the batteries in and it stays off unless I push on the cover. I have to push it just right to get it to stay on. Then when I am firing, the flash will go off sometimes, and then sometimes it won't consecutively, I hit the flash button consecutively and it will go off 5 times and then it won't a couple even though I will wait for the flash to get back to full recovery. It is frusterating when people at a wedding are waiting for you to get it right.
    Genius:
  • 1,689 Answers
The battery contacts are not making proper contact to the battery, or there is a cold solder connection in the circuit board inside of the flash unit.
There are photo shops that can have flashes serviced, or you can send the flash to the manufacture service department.
Unless you are able to do electronics service and are used to working on high voltage electronics at the component level I don't recommend opening the flash yourself.
Inside the flash they use very high voltage at very high discharge current. Even though the flash looks innocent and works only on a few simple batteries, this can be dangeriously deceiving. The discharge current can be very high, and the main flash capacitor can hold a lethal charge for many days!
Servicing and safety for photo flash units:
http://members.misty.com/don/xesafe.html
Jerry G.
Posted on Apr 19, 2008
Sb 600 not able to get out of standby
If you cannot release Standby from within the menu options, here is one thing I did: removed all batteries then pumped the on/off button numerous times. Upon replacing the batteries the issue is solved. If that does not work then it may need to go to Nikon. The SB600 seems to have more issues than the SB800 and up.
Oct 08, 2013 | Nikon Speedlight SB-600 TTL Flash
Hey I have a Nikon Speedlight SB-600... it stopped working.. I even put new batteries in it... no difference.. doesnt turn on or anything.. although I feel like I hear something shaking inside the top.....
Unless the nit is taken out the suspected component cannot be speculated. It can be a failure of the main capacitor, the inverter driver or the frequency circuit. If a visible part has come off the board then the solution becomes simple.
So remove and check to confirm and replace. Use a multimeter to check the voltage to the circuit, the power , the frequency generated and the drive.
Mar 12, 2011 | Nikon Speedlight SB-600 TTL Flash
My sb-50dx is making werid noises after a flash is
The weird noises could signal that the charge system is going bad, the very long warm up is not a good thing.. The flash may need to be repaired, but the cost of repairing an old SB-50 as compaired to buying a new SB-400 or Sb-600 has to be weighed. Take the flash to a local camera shop that sells nion and let them look at it.
Nov 13, 2009 | Nikon Speedlight SB-50DX TTL Flash
I have a Nikon Speedlight SB-600 that needs repair. The flash does not operate. I believe there is no connection made with batteries.
Check the battery contact make sure they are clean. If a battery leaked, even a little battery fluid on the contact then that could be the problem.
Nov 11, 2009 | Nikon Speedlight SB-600 TTL Flash
SB-600 Flash will not charge/everything else works.
check wire connection to capacitor measure voltage on it/
Be carefull high voltage!!!
May 12, 2009 | Nikon Speedlight SB-600 TTL Flash
SB 600 Not resetting...
my sb 600 speedlight won't turn on. Do I need to reset it? It has fresh batteries. Never been dropped
Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Problem with SB-600!!!!
Batteries may have leaked. Open battery chamber and clean ---especially the contacts situated at the bottom -- with pencil erazor. Blow out any loose bits and with new batteries try to switch the unit on.
Sep 18, 2007 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
125 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
