Question about HP DeskJet F4280 All In One Printer InkJet
Will not scan to PDF anymore - HP DeskJet F4280 All In One Printer InkJet
  • 78 Answers
Uninstall and reinstall the software - or try upgrading the software first. It could have easily become corrupt.
Posted on Jul 09, 2010
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
Hi , i cant scan jpegs anymore only pdf files since i installed windows 7 ive updated drivers ets im running 32bit , but it keeps coming up error code 12 1780 thanks
make sure the service for the canon scanner is running
start>search>services.msc look for canon service and check if its running, if its not put it in automatic then start it. hit apply then ok
Mar 23, 2011 | Canon CanoScan 3200F Flatbed Scanner
Symantec scan engine able to scan pdf malicious scripts?
Scanning a malicious PDF can be done with Symantec.
See http://support.symantec.com and search for Malicious PDF...
there is a support document for this.
Jan 19, 2010 | Symantec AntiVirus Scan Engine
HP 5590 - cannot scan and save doc directly to jpeg format
I need the scanned documents be saved as pdf in HP scanjet 5590
Apr 27, 2009 | HP 5590 ScanJet Flatbed Scanner
How do I clear the tabs on this IBS wheelwriter 1500?
Space the carrier all the way to the right, press and hold the tab clr key. press return this will clear all tabs rt. of the L. margin
Feb 06, 2009 | Lexmark Wheelwriter 1500 Typewriter
Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Cannot open pdf attchment
I had the same problem, and I solved it the following way.
The problem is that as soon as the temporary folder contains more than 100 "Document.pdf" (Document.pdf",Document(1).pdf",Document(2).pdf" etc...) it will not allow you to open anymore.
The only way around is to go in the temporary folder and delete one or more "Document.pdf"
To open the Temporary folder:
-open any pdf document that does not have this problem,
-Go to File and then to Save As.
Directly from there you can delete the "Document.pdf
You will then be able to open the Digital Sender scanned pdf document.
Oct 06, 2008 | HP 9200C Digital Sender
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
HP DeskJet F4280 All In One Printer InkJet Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
