Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire Model # fdb1050rec2 is leaking from the motor.
There is a leak coming from the motor what could it be? thanks
4 Suggested Answers
  • 22 Answers
SOURCE: Frigidaire dishwasher model GLD2250RDC0 leaks
You may want to check the door alignment itself. Many people open and close the door improperly and when they load it sometimes they put pressure on the door in one corner or the other. Check to make sure the door is completely shut and shut properly. It will be a pain, but let it dry out and tuck moisture revealing cream on the bottom seam. This will reveal where the moisture is coming from, but that is a pain. I think you will find a misaligned door is the culprit
Posted on Dec 23, 2010
johnpahl
  • 86 Answers
SOURCE: the top spray arm is
If your dishwasher does not fill up with the correct amount of water the top spray arm will not get the water pressure it should.
The water level should be just under the heating element.
Posted on Aug 03, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Leaking intake valve on frigidaire ultraquiet III, model: FDB750RCC1
    Hello Dan Wetmore - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, keep in mind that the springs or hinges may possibly be damaged, gasket not sealing properly or the leak could possibly be coming from the drain motor/pump (which would be more cost effective to repair). I would strongly suggest contacting a professional to move forward accurately.
    Posted on Dec 14, 2012
    How to install seal side seals on frigidaire dishwasher model number FGCD2456
    Hello Dwight, thank you for your inquiry!
    From my understanding you need helps installing the side seals on your Frigidaire dishwasher, FGCD2456. If your seals have been properly installed there may be another gasket causing the internal leak. Is it coming from the corner of the sides? This could be a possible issue with the lower door gasket or the door itself. I would check to make sure it is properly sitting on the hinges and not adjusted incorrectly. You may need to have a professional technician out to perform a proper diagnosis. Hope this help you with your repair. -Matt
    Jan 04, 2016 | Frigidaire Washing Machines
    Why does my frigidaire washer leak
    Hello friend, I appreciate your post!
    I see you are asking about a Frigidaire washer leaking but your question is labeled under refrigerators. If your washer is leaking it could be a problem within your motor, water valve, drain pump, or seal inside your washer. If you are speaking about a refrigerator it could be an issue within your water valve, water filter, or an air leak causing condensation.
    I would recommend having a professional come out to the home for a proper diagnose and repair. I hope this is helpful. -Matt
    Aug 17, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
    Frigidaire dishwasher leaks from motor
    This is caused by the cheap bearing's in the motor. Even after I have replaced my $200.00 motor assembly it still leaks. put a small flat dish under it as the leak should be small and when the dishwasher starts making a loud noise the bearings are gone and I do not recommend replacing motor as it is half the price of washer itself. I myself will never buy a fridgidaire again. However if you do replace the motor assembly it is very easy and there is a video on youtube showing you how. good luck
    Mar 25, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
    Working but extremely noisy freezer
    most likely noise is coming from evaporator fan motor.go here,it will show you the parts in your model,
    http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Freezer-Parts/Model-PLFU1778ES0/1428/0142000/R0510085/00002?blt=06&prst=&shdMod=
    unplug the freezer,remove shelves and remove back inside wall to get at the fan motor.you might see yellow stains around motor area,that's from the oil that leaked out of fan motor,also if noise stops and you notice that the freezer is cold on bottom and warm on top the fan motor died and needs to be replaced right away.hope this helps and you should change the motor out before you loose any food.
    Dec 08, 2013 | Frigidaire PLFU1778ES (16.7 cu. ft.)...
    Frigidaire built in dishwasher leaking water out of the bottom.
    One of the reasons could be door seal or sump seal leaking. But if the leak only occurs at a particular time in the cycle then most likely the wash motor or drain motor seals.
    Need the model number to make a more closer assessment.
    Dec 31, 2012 | Frigidaire Dishwashers
    Dec 13, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
    The top spray arm is not turning as best i can tell. bottom one is.. frigidaire model # fdb1050rec2. please help! thank you
    Aug 03, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
    Leaking door
    They had a big problem with this model leaking at the corners of the doors. I would replace the baffle (part# 154576501) and install a splash shield kit (part# 154701001, comes with instructions)
    Apr 07, 2010 | Frigidaire PLD4375RFC Dishwasher
    Leaking on the floor for several months
    The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
    Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
    Thank you for contacting Fixya.com
    Aug 10, 2009 | Frigidaire ATF6000ES Front Load Washer
    Open Questions:
    See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
    Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
    136 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Charles T Nevin
    Charles T Nevin
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
