Question about SATO CX400 Thermal Label Printer
I have a prn file generated using zebradesigner Pro. When i try to print the file using a Zebra tlp 2844 it does not print..what do i need to check. I tried with another prn file generated earlier and it prints.
I'm using ZebraDesigner and trying to print on a TLP 2844 printer, but it keeps printing across labels.
This reply is a bit late but for anyone else having this problem, you need to select the right orientation in your printer preferences in your software and in the printer driver, If you still have problems contact www.lancerlabels.co.uk
Home
Sep 17, 2014 | Zebra TLP 2844 Thermal Label Printer
WANT PRN FILE FOR BARCODE LABEL DESIGN
HOE TO DESIGN A PRN FILE FOR ZEBRA TLP 2844
Jun 03, 2010 | SATO CX400 Thermal Label Printer
How do i input text with this printer
Just like you would any printer. You could use word but word by default is set for a 8.5x11 full size paper so it must be configuared under file, page setup. Your label size gets entered and margins are zeroed out, or use the free label software called zebra designer which can be downloaded from this link.
http://www.zebra.com/id/zebra/na/en/index/products/software/label_design_software/zebradesignerpro/zebradesigner.html
Oct 05, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 prints slow in WinXP, but fast in
when submitting the print, un-tick the collate box. Use the properties section to check the speed settings in the driver and try again
Aug 13, 2009 | Zebra TLP 2844-Z Thermal Label Printer
How to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I have Thermal Zebra Printer TLP2824, I have installed it and
The printer has firmware TLP2844-Z Zebra. This printer uses ZPL commands and not epl. ZebraDesigner can print to a file and have a format command.
Jan 08, 2009 | Zebra TLP 2844-Z Thermal Label Printer
ZEBRA TLP 2844
plz try to use in another port(if available) or try with another cable
Jun 30, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Mar 25, 2008 | Zebra TLP 2844-Z Thermal Label Printer
SATO CX400 Thermal Label Printer Logo
878 people viewed this question
Top SATO Office Equipment & Supplies Experts
CheckitRight
CheckitRight
pkwc
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
