Question about Diamondback Response 26 Men's Front Suspension Mountain Bike
Fort Adjustment I have a diamondback response. Couple years old. I was wondering how I can adjust the forks to make it a little bit softer. It has Edge AL1 forks.100mm of travel.
  • 57 Answers
Check the top of one of the forks, there may be a knob type dial that you can turn clock-wise or anti-clock-wise, turning it one way will give you a stiffer ride, turning it the other will give you a softer ride. Some forks don't have this pre-load adjustment however.
Cheers.
Posted on Jul 09, 2010
I'm a bit confused about adjusting my rear shocks on a guzzi v9. Should the springs be made longer or shorter for a softer ride? And how does one adjust the dampers for a softer Ride?
Hi, David longer for a softer ride for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Guzzi, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Help needed re suspension upgrade advice
MOTO GUZZI V7 Racer User Manual Rear Shock Absorbers Adjustment Rglage...
MOTO GUZZI V9 Roamer Service Station Manual
http://www.harpermoto.com/oem-moto-guzzi-illustrated-parts-catalog.html
Owner manuals rider handbooks use and maintenance manuals
Apr 10, 2017 | 2017 Moto Guzzi V9 Roamer
How to reassemble diamondback outlook forks
Hi, Hugh for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Diamondback, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.diamondback.com/Data/Sites/12/media/support-owners-manuals/2012_om_diamondback.pdf
Fix Five Common Repairs
Diamondback Tech Fork Sag setup
Replacing Forks Shocks On Mountain Bike
Jul 20, 2016 | Motorcycles
Diamondback 460ub tension adjustment? how?
http://www.bing.com/videos/search?q=diamondback+460ub+tension+adjustment&qpvt=Diamondback+460ub+tension+adjustment&FORM=VDRE
May 22, 2015 | Diamondback Cycling
Bike squeeks from front suspension
put a couple drops of oil on the stanchion tubes of the shock forks where they seals connect with the sliders and see if that helps. It is possible that inside the fork it has dried out and the spring needs some grease where it seats inside of the fork.
Jun 25, 2014 | Diamondback Edgewood LX 700c Men's Hybrid...
How can adjust front shock f650gs 2007
It depends on what you want to adjust. There is no screw type adjustment on the shock itself.
If you are after a different feel, this can only be done by replacing the fork oil with a different grade or amount.
Typically the shocks will have a 10W oil and a 120mm air gap. Using a thicker oil will make then slower, thinner oil makes them faster.
Smaller air gap makes them harder, larger air gap softer.
Dec 26, 2013 | BMW F 650 GS Motorcycles
Loose crank
It is adjustable. But I would suggest to take it apart and lube the bearing assm.'s then set the adjustment. When setting the adjustment gently tighten the nut spin the sprocket assm. 5 or so turns to allow grease to spread evenly then back off the nut slightly and tighten nut enough to set a zero spec. in other words no side to side play and yet not tight (to tight and you can harm the bearings)
Mar 07, 2013 | Diamondback Outlook, 2012 171841
The first three speeds you get nothing....it only operates on high #4 speed and it is a little bit noisy
IF ITS AUTOMATIC TRANSMISSION. THROTTLE VALVE CABLE NEED ADJUSTMENT OR COULD BE THE GOVERNOR PROBLEMS LIKE VALVE STUCK GOVERNOR WEIGHTS BINDING. GOVERNOR DRIVEN GEAR DAMAGED OR.BURNED DIRECT CLUTCH PLATES.THE 1-2 3-4 SHIFT VALVES STUCK IN VALVE BODY. IF IT MANUAL TRANSMISSION SHIFT LINKAGE OR SHIFT FORK OUT OF ADJUSTMENT OR WORN DAMAGED OR I- 2- 3 GEARS AND BEARINGS WORN OUT.
Jul 09, 2010 | Cars & Trucks
Suspension adjustment for a 2007 Shogun Hydra
Have a look at this site:http://www.bikeforums.net/archive/index.php/t-15120.html and this site might help http://www.bikewebsite.com/suspension.htm You will have to either search for the manufacturers site and look for the adjustment info there( you should be able to download the manual for the forks ) or mention the specifics here so we can find them. According to my info your bike should have a Suntour SF-M3010db fork on it.
Aug 28, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Crf 450 front preload adjustment
Hi ...... Any preload and/or damping will be adjustable from the top of the forks (even upside down forks). Anti-clockwise to reduce, clockwise to increase. You may find that a previous owner has increased the 'weight' of fork oil as a cheap/easy alternative to adjustment or aftermarket linear or progressive springs.
Dec 29, 2008 | 2005 Honda CRF 450 R
Yamaha yz250 suspension settings
There is too much involved to include everything, but I can describe to you what everything does.
You have compression dampening which slows the rate at which the shock or forks can compress. Then you have rebound dampening which slows the rate at which the shock or forks can extend.
The compression adjuster on the rear shock is toward the top, sticking out sideways where the resivoir mounts to the side of the shock. The rebound adjuster can be seen below the swing arm on the side of the shock.
The compression adjusters on the front forks can be seen from the top. (its the one in the center, the other is an air bleed) The rebound adjuster is in the center of the lower fork leg, and can be seen from below the fork.
The settings are measured in the number of "clicks" from seated. More clicks from seated will be softer, and less clicks from seated will be stiffer. The best thing to do is to see where you are now and adjusting from there. I like to write them down as I go. Turn the adjuster clockwise untill it stops and take note of the number of clicks. DO NOT FORCE IT! You should also check your service manual and take note of the standard setting, and also take note of the maximum number of clicks you can go from seated. You dont want to screw the adjusters out farther than the max, shock damage can result.
You might try changing to the standard settings and try adjusting from there. If the bike doesnt ride at least moderately decent at the standard settings, your shock and/or forks may need a rebuild.
Generally speaking more compression dampening in the rear will result in less bottoming but a harsher ride. Less would result in the oppisite.
More rebound dampening in the rear will result in too slow of extension and packing up which will make the bike swap in the whoops, but it will not tend to buck you or throw you into a nose dive over a jump. Less would result in the oppisite.
In the front, more compression dampening will be about the same situation as described above with the shock.
More rebound dampening in the front forks can tend to take pressure off of the front wheel in corners causing washout, but too little can make the bike want to loop out over jumps.
Nov 21, 2008 | 2003 Yamaha YZ 250
Diamondback Response 26 Men's Front Suspension Mountain Bike Logo
403 people viewed this question
Top Diamondback Cycling Experts
Tony
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
