Question about Polaroid FLM-3734B 37 in. LCD HDTV
37" LCD Monitor FLM-3701 While I was watching it went out as if the power went out, but the cable box was still on. There is no indicator light on the monitor. I have unplugged and plugged using different outlets and it still will not come on.
    Problem Solver:
  • 11 Answers
Have the same tv and had the same problem. might be bad capacitors for the screen easy job to replace for the do it yourselfer and is not costly. just remove the back housing and feel the capacitors. if they feel like they bubbled up then they are bads and have to be replaced.you can find a step by step on youtube just type in the same info. good luck.
Posted on Jul 29, 2010
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa
Initially, the described problem with the Polaroid FLM-3701would indicate a power supply problem. While this could be nothing but a fuse that blew, a faulty cord / plug or even no power to the outlet, it could also be caused by failure of the power supply to fully turn on either:
  • auto-protect has kicked in to prevent further damage;
  • the power supply itself has faulted and could not produce sufficient voltage to operate the unit.
This is then a hardware fault and would require that the unit be opened up to effect repairs.
Options then are:
  • consider a DIY (do-it-yourself) repair if and only if comfortable working with electronic components & circuitry, use of a DVM/VOM, a soldering iron/station and safe practices with electrically powered devices. Access to a Service Manual or at the very least, a schematic diagram would be a necessity;
  • should you be uncomfortable with a DIY, perhaps your best bet would then be to consult with and/or seek the services of an authorized Service Center or a qualified professional.
Offhand, while test points, voltage checks and repair steps could be provided, it is necessary to use a multimeter to determine voltages at certain pins while the Polaroid is live. Is a DIY being considered?
Good luck and thank you for asking FixYa.
Posted on Jul 09, 2010
Polaroid LCD
It looks like your power supply might not be providing enough current to get the LCD to power up. This LCD needs about 3 to 4 amps to work properly.
Apr 12, 2008 | Polaroid FLM-3701 Television
Polaroid FLM-3701 power
Unfortunately modern televisions and monitors are full of electronic semiconductors of which many are likely have got destroyed along with your original power supply during the storm. A nearby lightning strike will send high voltage spikes down aerial cables as well as through socket outlets.
If you have contents insurance you should be able to claim for a new monitor.
Nov 09, 2013 | Polaroid FLM-3701 Television
Hi, my LCD Polaroid FLM-3701 went through a power outage and now doesn't get power any more. The power led doesn't show any light. I saw a capacitor repair kit available, and four 680 uF capac
The power supply fuse should be next the the ac input plug on the power supply. It should be a long cylinder type fuse, probably a T6.3AH/250V. You will want to replace those caps ASAP
Nov 05, 2012 | Polaroid FLM-3701 Television
Is there a coaxial input on this tv?
No because it is a monitor only; meaning it does not have a TV tuner of its own.
Sep 23, 2012 | Polaroid FLM-3701 Television
Where is the fuse in a 3701 LCD Polaroid TV/Monitor
In the Polaroid FLH-3701, the fuse is located on the power supply board, next to the AC power connector. It is a small black cylinder. It is labelled F1. Value is 5 amp, 250 volts.
A fuse does not blow for no reason. Most commonly a fuse will fail because of a short someplace on the board. I have this same TV. The fuse blew. The reason was transistor Q6 had shorted. There are two identical paired transistors on the output side. Q6 and Q7. They are both Infineon 11N60C3 MOSFET transistors. Check those for a short. There may be a burnt smell.
More commonly, this TV will fail because of bad capacitors on the power supply board.
May 08, 2010 | Polaroid FLM-3701 Television
Our electricity went out and now we have it back on
Most times when a power outages occur, most everything that's plugged into an outlet receives a "Power Spike". Basically it's a shock wave traveling through the neighborhood power grid when the electricity turns OFF and ON.
Hopefully the TV didn't receive too much damage. Inside the TV, there is a fuse that may need to be replaced. Radio Shack or other electronic store will carry these fuses. If this doesn't solve the problem, the Power Supply Board maybe damaged.
Jan 28, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Connect from wall cable to tv.
you are trying to use a monitor as a tv, you will need a tuner to get a pic, use a cable box or digital to analog tuner to get something
Nov 17, 2009 | Polaroid FLM-3701 Television
37 inch Polaroid monitor Stopeed working
This sounds like the power supply board has gone bad. Someone knowledgeable in electronics can check the fuse(s) on the board. If necesary, the board can be replaced.
Dec 21, 2008 | Polaroid FLM-3701 Television
Polaroid FLM-3734B 37 in. LCD HDTV Logo
264 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
