Question about Brother MFC-5840CN All-In-One InkJet Printer
I replaced the Absorption Pads and Flushing Case but still have..
I still have the message on the screen saying "Unable to Clean". Is there a way of reprogramming the printer now that the problem has been fixed and if so what is the procedure?
  • kdill777 Jul 09, 2010
    Yes it solved that issue but I still have an issue with my black ink not working yet.
    Using Cotton and Hot Water did not work to get the black ink to work.
    Any other suggestions?
    President:
  • 3,278 Answers
Hello.
Since you replaced the absorber, etc., you need to reset the purge counter to zero.
1) Enter machine maintenance mode. Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Hope this helps.
Posted on Jul 09, 2010
  • 2 more comments
    It did work Thank you!
    If I need to purchase more absorption pads and a flushing case can you refer me how to purchase these items?
    I can print out things but only the color items come through the black does not.
    Can you offer steps to get my black ink to work. I just put in a new cartridge.
  • NinaE Jul 09, 2010
    Try cleaning the black print head:
    (1) Open the printer
    (2) Remove the black ink cartridge from the print head.
    (3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
    (4) Repeat this until there is no ink residue coming off on the cotton swab.
    (5) Once finished, allow to dry and replace the cartridge
    Again, hope this helps.
    If the hot water is not cleaning the print head, use isopropyl alcohol, instead. If the print head is clean but still not working, your print head could be faulty.
Having un abale to clean on 425cn
Unable to clean pretty much means that the ink absorber pads have become full, this means the printer will need these replacing, also when you replace this the flushing box has to be replaced aswell. In all honesty it is cheaper to buy a new machine then get these replaced as a service enginner has to do this.
Oct 08, 2012 | Brother MFC 420CN All-In-One InkJet...
My printer brother dcp-330c have "unable to clean 46" problem.. the answer in your website doesn't help as i was unable to enter the maintenance mode from the instruction.. my printer does not...
I developed the same problem "unable to clean 46" on my brother dcp -330c printer.. after taking to a maintenance guy... he told me to remove my ink absorption pads and wash them out with water and leave to dry then once dry replace back in..
Apr 14, 2011 | Brother DCP-330C All-In-One InkJet Printer
Machine says Unable to Clean
The unit needs to get new waste pad and flushing box. Cost for the parts are approx. $25 plus service.
The pads are almost fully saturated with ink and requires a replacement
Thanks
May 11, 2010 | Brother MFC-5840CN All-In-One InkJet...
Brother DCP-135C Error message CLEAN UNABLE 46 How do I clear this please. I don't want to pay for an engineer. Thank you.
The error you are getting is telling you that the
Waste Pads have to get replaced because they are saturated with ink.
The sets of pads run under $20. The Upper set of Pads is not too hard to replace, you need to take the scanner assembly off, upper cover and control panel and the flushing box is in the back. The second pad requires taking out the printer mechansim and platen roller , bottom plate and possible removal of printhead. I do not recommend you doing this.
The unit then needs to get reset.
thanks
May 02, 2010 | Brother MFC-5840CN All-In-One InkJet...
Clean unable 46
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Apr 09, 2010 | Brother DCP 165C Compact Color Inkjet...
My unit has a unable to clean message on the screen and I do not know where my manual is (just moved) How do I fix this
The ink absorber box and the flushing case will need to be replaced. Then the purge counter and the flushing counter will need to be reset to 0.
Aug 03, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
46 means the flushing tank is full. All you can do is take it to a shop to replace the flushing box and reset the count to get rid of the error...
Jun 29, 2009 | Office Equipment & Supplies
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Error # 46 - Absorption Pads need replacing
same issue (plz read my answer here):
http://www.fixya.com/support/t202282-unable_print_unable_int_unable_clean
Feb 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
