Question about SanDisk 2GB microSD Memory Card
How to remove write protection on a memory card
  • 45 Answers
Removing the write protection depends on the source of the problem.
Broadly speaking, it can be any of the following scenarios
  1. There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  2. There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  3. The mini sd card has some error: Go for a low level formatting.
  4. The card has virus: Remove the virus. The link for the steps is present in the related link at the bottom of the article.
There is an easy way to solve this problem: Simply put the yellow lock in the middle of its slider. No sticky tape required, as shown below. But if your still having the same problem i suggest you try the sticky tape.
problem is only that small moveable yellow lock switch is not making, just put sellotape over it maybe two layers needed to make switch.
== Answer == Even though what is written below may work, the problem is probably that on the card reader (if you have one) there is a small switch that has lock written on the side. If this is pushed down, the drive is write protected, push it in the opposite direction and it may fix your problem I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
Your card should work fine now... don't know why this has to be done, but it works! Additional info:
Reason #1,
the mechanical lock switch accidentally moves to the "locked" position during insertion due to the poor quality of the switch. Hence, by taping it, you are actually preventing the lock switch to travel towards the lock position. i.e. downwards.
Posted on Jul 09, 2010
Plz help me to remove write protection from my micro sd card.
Hi, slide up the Write protection switch which is white in color for the Memory Card Adapter to remove Write protection and Slide down to enable write protection of the Memory Card.
Please click on the link below to view the Write protection switch:
http://kb.sandisk.com/euf/assets/images/faqs/id1102_e3sdhc.gif
If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Apr 16, 2011 | SanDisk 2GB microSD Memory Card
When i try to add music in to my card adapter pny SD 2 gb it says it has write protection and to take it off what do i do?..
To remove write protection
In your memory card adapter have a switch to on/off write protection.
pull this switch to down ,you can remove write protection of your memory card
thank you
Dec 23, 2010 | PNY 2GB microSD Memory Card
hai friend
thank you
Dec 19, 2010 | SanDisk 2GB microSD Memory Card
I would like to remove write protection. Is this possible? Thank you for your assistance in advance. George Van Etten
thank you
Dec 18, 2010 | SanDisk 4GB microSDHC Memory Card
How do i remove the protected card from my camera
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 27, 2010 | Fuji FinePix A201 Digital Camera
How can i remove the write protect in my memory card if it doesnt have a slidable lock
The procedure for removing the right protection is given in the website given below.
please follow the directions and you can remove it.
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
Thanx
Jul 20, 2010 | SanDisk 2GB microSD Memory Card
My memory card is write protected.how to remove it?
Some SD cards have write protect tab on the side but not all do so check for that tab. If it does not have write protect it may be you device you using it with or the memory card as a whole has gone out on you.
1. Check for write protected tab on the sides of the card
2. Check the device (try reformatting it in a card reader)
3. Replace memory stick.
Thanks and please do be considerate when leaveing feedback and ratings today, thanks
May 30, 2010 | SanDisk 1GB microSD Memory Card
Memory card protected
If your memory card is protected, remove the memory card. Look at your memory card you can see there a small push button push it so that the card will not protected. Reinsert your memory card to your camera.
Regards
PCmania
Sep 28, 2009 | Kodak EasyShare C653 Digital Camera
To remove write protection of my memory card for nokia 6630
we have dissame phone model... and i think i can help you ... get the memory card and a card reader and connect it to a computer then format .....in the computer you can format it
Jul 24, 2009 | Nokia 3230
SanDisk 2GB microSD Memory Card Logo
463 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
