Question about GE Refrigerators
Model GSS22JERFBB Freezer not auto defrosting causing refrigerator to not be cold. If I unplug over nite, works perfect for a couple of weeks and then goes out again.
  • syharris2 Jul 14, 2010
    This info was on point and extremely helpful Thank you SLAMFIX!
    President:
  • 670 Answers
What is probally happening is that ice is building up on the evaporator coil in the freezer blocking air from circulating from the evaporator coil to the the refrigerator compartment. The defrost circuit is supposed to stop the compressor for about 30 minutes and allow power to go to the defrost heater via the defrost thermostat to melt any frost build up on the evaporator coil.
There could be three parts that could fail that would cause the defrost to stop working, the defrost timer/module, the defrost heater and the defrost thermostat.
The defrost circuit is controlled either by a mechanical timer or an electronic module. I think your model uses a module. It switches power from the compressor to the heater. It could be located either at the front bottom of the refrigerator or in the back of the machine. The heater and thermostat is attached to the evaporator coil. The evaporator coil is located at the back wall of the freezer behind the plastic panels.
I don't know if you are able to service the refrigerator yourself, if not, then call a service company and ask them to check the defrost circuit. If you are technical, then below should guide you to figuring out the problem.
To check to see if the problem is with the heater and thermostat, you will need an electrical meter. To check you will need to unplug the refrigerator, empty out the freezer and remove the panels to expose the evaporator coil. Then using a hair drier melt the ice off the coil. While you are doing this, the drip pan on the bottom of the refrig will need to be emptied periodically if you don't want water to pool beneath you. After the ice has melted, check the continuity of the heater with the meter in the ohms scale, if it is any more than a few ohms, then the problem is with the heater.
Hope this helps you.
Posted on Jul 09, 2010
  • 1 more comment
  • syharris2 Jul 09, 2010
    Is it possible for you to confirm the defrost for my model? Based on my model, can you confirm exactly where the module is if that is the control mechanism? Is it in the front or back? It will make it easier for me to trouble shoot. I'm technical as I manage electronic technology, trouble shoot massive computer/data base issues, build computers but I've not worked with refridgerators before. With your guidance though, I may have some success.
    Your Comment......
  • Stephen Lam Jul 09, 2010
    I checked the model number that you supplied GSS22JERFBB with partselect.com and a diagram shows the main control board is mounted on the back of the refrigerator. You can confirm this by removing the access panel from the back of the refrigerator and look where the wires are attached to the compressor and tracing them to the control board. From this board you should be able to trace the wires to the heater circuit. When you locate them, you can verify if the problem is the board or the heater/thermostat.
    To do this, unplug the refrigerator while the freezer is still cold, (below 30 degrees F) then remove the wires that connect to the defrost heater from the module. Then ohm out the two defrost wires. If the ohm reading is below 30 ohms then the defrost heater and thermostat is good. If it reads infinity, then the problem is with the heater/defrost thermostat. From the partselect.com site you can order the heater/defrost thermostat. Let me know if you need more info. Thanks.
  • Stephen Lam Jul 14, 2010
    Glad that I was able to help you. What did you discover was the problem?
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
FRT221RSH refrigerator warm...freezer cold...some frost on back of freezer wall, i popped off the small cover on the inside back wall of the freezer and the fan there is running...i vacuumed a little dust...
If you remove the entire back panel of the freezer section there is a evaporator (aluminum grill looks like a car radiator, contains r-134a, do not puncture or unit is ruined) Some frost on back freezer wall, means probably this entire grill is encased in frost, not allowing any air flow, which is how the entire refrigerator section is cooled, by air flow) The frost build up has to be removed,(got a hair dryer) you can unplug it for a couple of hours with the door open, overnight is better,this would fix the problem for a couple of weeks....Your automatic defrost is not working, there are three parts- the timer or control board, a heating element, and a bi-metal thermostat(often the problem)
You popped off the cover for the ice maker, you need to defrost the whole freezer section behind the back panel. Freezer cold means your compressor and freon are fine, you have a defrost problem with ice build up restricting air flow. A normal automatic defrost runs every 8 hours, three times a day, rule of thumb.....Sounds like you have a couple of weeks built up...........
hope this helps
Feb 23, 2011 | Refrigerators
Danby DFF8803W freezer keeps freezing up. What causes this?
Some models are a manual defrost. That meant every 3-4 weeks you must unplug it and let it defrost. These types usually have no fan in the freezer, instead it's a cold plate. If there is a fan in your freezer section it should automatically defrost. You might have a bad defrost clock, or a bad defrost heater.
Nov 02, 2009 | Danby DFF8803 Top Freezer Refrigerator
Refrigerator and freezer quit working.
That sounds like it could be the problem. The common causes are a bad defrost heater, defrost timer or a defrost thermostat.
Aug 27, 2009 | Belling BE811 Bottom Freezer Refrigerator
My Magic Chef refrigerator has stopped cooling. When I unplug it for a few days, and then plug it in, it will work for about a week, and then quit cooling again. The freezer is perfect, and continues to...
The most likely cause is that the defrost system is not working. After about a week it builds up with enough frost to stop the cold air from getting to the refrigerator section. The most common problem is the defrost timer, defrost heater or defrost thermostat.
Aug 26, 2009 | Magic Chef CTB1502AR Top Freezer...
After 1 or 2 weeks the refrigerator stops working, it freezes up. After defrosting, works perfect for 1 to 2 weeks again
Defrost heater bad, defrost thermostat bad or Defrost timer. Defrost heater and Thermostat can be continuity checked. Defrost thermostat can only be checked if at freezer temperature. Both should show continuity if good. If those two test good the process of elimination means it's the defrost timer. Always unplug refrig when performing these checks
Aug 22, 2009 | Avanti FF511W Top Freezer Refrigerator
Sharp SJ-42-WH self-defrosting fridge. Freezer works fine, but fridge doesn't cool down - no airflow to fridge. 1. Damper working perfectly and not jambed in closed position. 2. Fan working...
I recently had exactly the same problme with this model refrigerator. I found the problem to be the defrost timer. It is located behind the panel on the back of the refrigerator where the mains cord is located, you will need to replace it with the exact same model. I am in Australia and managed to find the exact part on ebay cheaply from a local appliance parts supplier, any appliance parts supplier that deals in Sharp refrigerators should be able to help you.
You will have to defrost the refrigerator overnight again before doing this repair.
Of course there are a couple of other components that could cause this problem, you can acutally check to see if the defrost time is moving by taking note of it's current position and then checking it every thirty minutes or so. If it does not move then it could be faulty, make sure also that power is getting to the timer as well.
Sep 26, 2008 | Refrigerators
Fridge freezer
Defrost timers usually cause this type of frost build up. However it can also be caused by the defrost heater and/or heater thermostat, and these items are behind the panels therefore not easy to get to. Also before you attempt to take the panels apart make sure the refrigerator is unplugged.
Aug 04, 2008 | Candy Freezers
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
