Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Refridgerator compressor starts and stops, its a ten year old superba from kitchenaid. i want to think its a relay but if its the compressor, is it going to break the bank to fix?
Check to see if the compressor is bad by putting your meter on the ohm setting. check each terminal togther and then also to ground if it beaps when it goes to ground it is a bad compressor. BUT it should beap when you check each termianl togerther. there is three leads one is start one is run and one is common. if you have contunity between these it is a good compressor. i
Posted on Jul 10, 2010
I have a KitchenAid KSRS251 side-by-side refridgerator that is clicking every couple of minutes and the you can hear an motor or something run for a few seconds. The freezer is defrosting and I think...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Fridge stopped working both freezer and fridge, Here clicking at compressor, compressor not starting, cooling fan and everything else OK, could it be the compressor or is there a chance the thermal switch...
This is a bad compressor, or overload-relay kit. Disconnect the power, remove the overload-relay from the compressor, and test the three compressor terminals for continuity . You should have continuity between each terminal, and you should not have continuity between any terminal and ground. If this tests ok, then replace the overload-relay kit. This is a common repair for me, and it is very rare for us to find a bad compressor, so you should be ok. If it is a bad compressor, and it is less than five years old, you have a five year sealed system warrantee, that will cover the repair cost. If it is over five years old, it is not worth repair. When you are done with the repair, make sure you install a 2000 joule or higher, surge protector to protect your refrigerator from this type of repair in the future. Good Luck, Appliance Specialists
Mar 14, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Our kitchenaid superba refridgerator stopped. Not sure what to do?
first you should send the model number so i can look up your machine,if the compressor isn't running you could have cooked the start device on the compressor,if you hear a clicking sound but no compressor and the freezer and fridge are wasm that's where i would start
Feb 18, 2011 | Refrigerators
Stopped cooling in freezer and refridgerator
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Nov 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
Compressor not running
you can try to repalce the "overload relay", with the model numberlook up the correct part. i would also check with oyour manual perhaps you have an extended warr. on your compressor assembly( comes with a new overload relay)..
Mar 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba compressor
The compressor relay is located on the compressor under a cover. Before you go to the compressor I would check for other problems that you can see and hear. If the compressor is running there is nothing wrong with its relay.
1. Check the condenser and make sure it is clear and free of dust.
2. If the compressor is cool or cold check for a bad temperature control.
3. Check the freezer compartment for frost on back wall.
May 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superba
To the person who hears a clicking sound you are correct, the compressor is trying to start but is not starting and that causes the overload to trip (click) wait a short time and it all happens again. Either the start relay is bad or the compressor is locked up. Less than 1 year old should be in warranty. If you want to try to check the relay you will need to unplug it from the side of the compressor. Once removed try to shake it and if you hear a rattle noise the relay is bad. To test the compressor you would need a test tool or be very experienced to perform accurate test.
supertechks
Nov 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
147 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
