Question about Toshiba Computers & Internet
My toshiba laptop has gone into hibernation how would i get it out of hibernation please?
    President:
  • 2,600 Answers
To get out of hibernation on all computers with Windows....you simply have to push the power button once and the system is supposed to come out of it. If it does not, power the laptop off, remove the ac adapter power and then remove the battery. Push the power button to bleed any residual power in the capacitors. Plug in the AC adapter and power the laptop back up. It it boots, go ahead and replace the battery. You then may have an issue with hibernation on that particular computer. My advice is to go to the control panel > power options > hibernation tab and uncheck usinf hibernation. Most modern computers do not need this if they are sleeping or if you just want to shut the system down. There have been more bad registry problems with hibernation than any other thing.
Posted on Jul 09, 2010
    Genius:
  • 1,189 Answers
  • Hi, in most [Hibernated States], pressing the "Power Button" (1) time, will bring the Computer out of the "Sleep." To ["Disable"], the Hibernation, or if you choose not to use it at all! Click on the "Start Button, in the [Start Search ] window" type: power. In the next window "Power Options," you can choose from the different categories in the (left pane), how and what your preference is, to controlling the way, and when the Computer "Sleeps..." Thanks for using Fix'Ya, and if you get a chance, let me know how things worked out for you."
3 Suggested Answers
babb
  • 104 Answers
SOURCE: My Toshiba satellite L20 laptop has gone into hibernation mode and I cannot swit
Try reseating the battery(Basically try taking out the battery for 10 secs then putting the battery in). The battery is located probably behind and under the laptop!! If that does not help, there could be something worse wrong with your laptop. When you plug it in does the indicator show that its plugged in? regards, babb
Posted on May 06, 2007
  • 60 Answers
SOURCE: hibernating to black screen even when hibernation option is off
Try some antivirus
Posted on Jun 17, 2009
My toshiba computer has turned off and a red light flashes when I try and turn it on again
Sounds like there is no power to the laptop so teh laptop has gone into hibernation. Make sure that the laptop has working mains power.
Dec 10, 2013 | Toshiba Satellite Computers & Internet
My toshiba satellite pro a210 1az just stops after about 10 mins of use. the power light stays on but it is as though it has gone to sleep but the only way to get it to do anything is to power off with the...
Check if its in the hibernate mode instead of sleep. there's a short cut key to resume for hibernate check the user's guide in the laptop manufacturer's website.
Mar 15, 2011 | Computers & Internet
My laptop doesnot come back from hybernation. I have xp on my Toshiba laptop.
Common problem with a lot of laptops.
I recommend you shut it down as opposed to let it hibernate or just turn off hibernation
Start... Control panel.... Power options... Hibernate ... uncheck the box "Enable Hibernate"
Jan 03, 2011 | Computers & Internet
Hibernation
take the power out, take the battery out wait 2min and then power on
Mar 09, 2009 | Toshiba Satellite L25-S119 Notebook
Hibernate
When Windows opens then -
Open Control Panel - then click on Power Options - Click on Hibernate tab and uncheck Enable Hibernate - Click OK
Feb 13, 2009 | IBM ThinkPad T23 2647 Notebook
Enable standby and hibernation in my laptop again
You can manually re-enable the Hibernate option via command prompt using these instructions:
  1. Click the Start button.
  2. Select All Programs > Accessories
  3. Right-click on Command Prompt and select Run as administrator .
  4. At the command prompt enter
    "powercfg -h ON"
  5. Close the command prompt window.
Nov 27, 2008 | Toshiba Satellite L25-S119 Notebook
Toshiba Qosmio F15 AV201 - permenant hibernation
i have the same problem but the power is completely shutdown
Oct 22, 2008 | Toshiba QOSMIO F15-AV201 Notebook
How to turn on toshiba satellite M300 laptop from hibernating mode
hi shirleygty, is that automatic hibernation (the computer hibernates by itself) or manual hibernation (by pressing the hibernate button)? If either applies to your case you might need to update the BIOS information for your computer to fix the power management issues on it. You can get it here. Just run the file, click install & choose Install From Windows. Make sure you don't have any BIOS password or any external devices connected to the computer. When the update completed successfully, your computer will automatically restart, then try hibernating this time (manual or automatic). I do recommend setting the hibernation to 1min. at the control panel > power options > change when to turn off the display. When it hibernates, pressing any keys or the power button should wake up the computer.
Hope this helps.
Oct 05, 2008 | Toshiba Satellite A205-S4617 Notebook
My Toshiba satellite L20 laptop has gone into hibernation mode and I cannot switch it on at all.
May 06, 2007 | Toshiba Satellite L20-S310TD Notebook
Computers & Internet Logo
477 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
