Question about Dell Inspiron 6000 Notebook
Battery light flashes orange three times then green. It doesn't impact battery life or operation. Is there a danger I that I might lose all my data? can I safely continue using laptop with ac adaptor pliugged in without fear of corrupting or losing data? thanks in anticipation
    President:
  • 2,600 Answers
This indicates either a faulty battery, charging circuit or motherboard issue with the charging port or charging circuit.
You can run the laptop solely on the ac adapter without issue as long as you have steady power. Try removing the battery and plug in the AC adapter and see if the laptop gives you the same light flashes...if it does, you maybe having an AC adapter issue. Try running the laptop solely on the battery and see how long the charge lasts.
Hopefully, all you are dealing with is a battery that is losing a few cells but is still capable of functioning...then you just have to get a new one.
Posted on Jul 09, 2010
My battery wont charge and the battery light on laptop flashes a few times orange and green and i went into settings it says its idle and not installed for my dell latitude d600
The battery has a fault and needs to be replaced. Unfortunately when you get this condition is is usually a dead cell in the battery and to try and force charge it is dangerous.
Sep 10, 2011 | Computers & Internet
Tip
Dell Portable Battery LED flashes Orange 4 times then Green once
This LED flash pattern, Orange, Orange, Orange, Orange, Green (Repeats) indicates a internal failure of the Battery. Pressing the charge indicator button on the battery (If equipped) will give a 1 3 5 LED on indication which also indicates a failure in the battery.
The battery may still function, but at less than optimal performance and will have a progressively shorter functional life until it dies.
The only way to resolve the issue is to replace the battery.
on Dec 23, 2009 | Computers & Internet
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
Is the lightening bolt supposed to flash orange? The battery will not keep a charge at all, so I have to keep it plugged in all the time. Does the orange flash mean I may be in danger of losing files, etc....
The orange flashing lightening bolt is confirmation the battery does not charge. It is not an indicator of any other hardware failure.
You can remove the battery if you find the flash annoying. The laptop will be lighter without the battery too!
Sep 21, 2009 | Dell Inspiron E1705 Notebook
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Jun 17, 2009 | Dell Inspiron 6000 Notebook
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Flashing battery icon
Battery is shot, time for a replacement. Keep in mind that a Dell battery can aquire a dead short, this won't hurt the system, but it can keep the machine from starting up. If you find that your machine won't start up try pulling the battery.
Jun 10, 2008 | Dell Inspiron 6400 Notebook
Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
Jan 20, 2008 | Computers & Internet
Dell Inspiron 6000 Notebook Logo
153 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
