Question about Yamaha 12V Air Pump
I have a 2001 Yamaha Waverunner 800XL. It has worked well in the past, but now when I start it the motor revs high and it takes off out of control. The speed can be slightly controlled by the choke. The jetski repair guy I took it to thought the carbuerator needed a new diaphram (something like that...not sure) but the part came in and it didn't fix the problem. He's scratching his head now and it seems like no one works on jet skis anymore? I have read somewhere on the web that this is a common problem with this model (I wonder why no recall, as dangerous as it is) but I can't seem to find the info anymore. Any ideas?
  • 10,865 Answers
Hello. These waverunners have a problem with throttle cable corrosion. When the cable corrodes you get that reving and lack of control
replace the cable and solve the problem. J.
Posted on Jul 09, 2010
  • judisunshine Jul 10, 2010
    Thanks for your suggestion. According to the repairman, the cables are fine. He has also lubricated them (not sure what he used). Is there anything else you can think of?
    Judi
Yamaha 1100 waverunner
they dont do a 4stroke 1100 high output ! 1800HO then 1800SHO !
Aug 08, 2014 | Boating
Waverunner does not stop with kill switch
The switch suppose to ground the coil for the spark plugs, try to remove the kill switch and verify the continuity of the switch contacts.
Jul 04, 2014 | Boating
Yamaha waverunner
Well if you have no money to fix it then no use figuring out what is wrong. Sorry but repairs take money, I am sure this is at least a $200-$400 USD repair job. Check your fuel pressure first.
May 03, 2017 | Sport & Outdoor - Others
Yamaha waverunner
check for corrosion of the engine as leaving it for long any water left in the system will cause problems.
May 26, 2013 | Yamaha XL700Z Waverunner
YAMAHA WAVERUNNER 2000 XL 800, WILL NOT RUN PAST 12 MPH
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
Apr 05, 2010 | 2003 Yamaha YZ 250
I have a 2001 yamaha waverunner and the gauges stop working
I have a 2001 waverunner and it stoped runing in the water . Now it will turn over but won't start
Sep 29, 2009 | Boating
I have a 2008 Yamaha vx110 deluxe waverunner that idles high.
I dont know the answer but my vx deluxe is doing the same thing. Not as bad as yours but 4k rpm idle.....ANyone?
Jul 13, 2009 | 1997 Acura CL
MY YAMAHA WAVERUNNER 3 RUNS GRATE FOR ABOUT THREE MIN AND THEN ACTA LIKE THE REV LIMITER KICKS IN IVE REPLACED THE COIL AND OVERHAULED CARB ANY HELP WILL BE THANK FULL 1992 650 YAMAHA WAVERUNNER 3
You should check your feul filter or maybe the feul tank it could be you have trash in your tank and it takes a few minutes to pick up the trash and restrict feul flow possibly not clogging the filter all the way allowing just enough feul for it to idle
Jul 08, 2009 | 1979 Yamaha XS 500
Yamaha 12V Air Pump Logo
341 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
