Question about Kenmore Ovens
Kenmore oven model 91141059591 will cut it self off after 30 minutes.
watugot
  • 290 Answers
SOURCE: Kenmore oven locked after celf cleaning
Try putting it back into clean mode and and listen for the lock motor to start turning. If you can hear it, keep trying the door until it opens. Don't hold steady pressure on the latch, just pull a little then let off. After you get it open, hold in on the door switch and cancel the clean mode and it should go back to correct position.
If this doesn't work, you may have a failed door latch, control, temp sensor, or switch. Post back with the complete model number and I will look it up and see which latch assembly you have and see if we can get it unlocked manually.
Posted on Oct 21, 2007
SOURCE: F2 message when self cleaning
I have the exact problem, had a service man look at it while still under warranty. He said it was fixed and left. Tried it again, same problem. Called him back 2 times after that, he quit responding to my calls. By tyhen warranty expired and GE refused to do anything.
Posted on Dec 16, 2007
ginko
  • 19396 Answers
SOURCE: GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Posted on Jan 02, 2009
  • 744 Answers
SOURCE: Message f 30 on my kenmore oven after I used the
F30 is a warning code indicating that the oven either has overheated or that the sensor may have activated the error code.
There is a sensor inside the oven that should have a resistance of about 1,100 Ohms at room temperature. If the resistance is out of range then you will need to replace the sensor.
If the resistance is within tolerances then the problem is the clock control board. Also check for any loose or bad connections.
Posted on May 10, 2009
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Posted on Aug 27, 2009
When I turn on the self cleaning oven, it makes a loud buzzing noise. Is this normal? If not, what needs to be fixed and how do I do it?
The buzzing sound comes from the relays located on the control board. Remember, the oven gets very hot during self clean, so the control works at full speed to get all the elements working.
Jan 03, 2015 | Kenmore 30 in. Electric Self-Clean Single...
Replace thermostat on kenmore elite
Possibly none of these videos are exactly like your oven but it should give you enough information to get the job done.
Note that some of the videos are not for ovens.
Replace thermostat on kenmore elite oven YouTube
KENMORE ELITE Walloven Parts Model 79048033800
Oct 16, 2014 | Kenmore Elite 30 In. Electric Self-clean...
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Heat cuts off on oven after being on for about 30 minutes. Code F2 appears.
Hi, F2 code means that the Oven temperature is too high.....
Solution:
  • Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
  • For SELF CLEAN models: check door lock operation.
  • Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember:
  • Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Oct 14, 2010 | Whirlpool RBS275PD Electric Single Oven
How do i unlock after self cleaning my kenmore elite electric slide in 30"
Hello,Give it time for the oven to cool if it has just completed the clean cycle. The door is not to unlock if the oven is still too hot. If the oven is cool and the door will not unlock,program and start another clean cycle and after about two minutes press cancel/clear/stop and wait for another minutes to see if the door will unlock.If the door doesn't unlock i recommend calling a service technician to diagnose and repair your range.
Thanks
May 29, 2010 | Kenmore Ovens
Advise use of self clean feature on kenmore self clean oven 30''
If there is an up and down arrow on the control panel, you need to press the clean button first and then choose clean time with the up and down arrow. Be sure to remove the racks, if left in the oven they will be blackened by the extreme heat. Clean them separately with oven cleaner. Place them on newspaper and spray them.
Dec 07, 2009 | Ovens
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Ovens Logo
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
