Question about Canon CanoScan 4400F Flatbed Scanner
Every time i try ti scan using my canon 4400 it
Every time i try to scan using my canon 4400 it comes up saying not enough space. it did not do this before. Any ideas/
2 Suggested Answers
SOURCE: Won't scan - says not enough disk space.
I had the same problem. Solved it by going into the "CanoScan Toolbox" - "Settings" - and pressing the "Defaults" button in that panel - and then "OK" button. Afterwards everything worked fine. Hope this helps you.
Posted on Apr 01, 2009
I have been using it for years, suddenly starts to present an add same "There is not enough free disk space to complete scan..." What is it? What can I do?
Hi
Scanning require disk space in you computer. Try to remove some clean up or remove some document files in your hard drive to free some space. Check also your C and D drive jf how much disk space it available.
Jan 13, 2011 | Canon CanoScan LiDE 500F Flatbed Scanner
Scanner sends message "Unable to scan. Make sure there is enough space on target disk"
Check the resolution settings.  If you're trying to scan at 9600dpi, the image will be huge, it may not fit into ram either, so the swap file would be used and you would need twice the file space to scan the image.
Scanning at 600dpi is generally fine enough for most uses (300 or less for web use), including scanning photographs (you may want to scan negatives at 1200 though.)
JBV^_^
Sep 01, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
My Cannon Lide 90 only scans one document. try to do another it says ''the scanner is not available when in use by another application or user'' I close it all out, try again & same thing. I removed...
Check your hard drive space and system RAM requirements. Often this happens because there is not enough "Scratch Pad" space..OR RAM these days 4GB is too small sometimes.
Jan 28, 2010 | Canon CanoScan LiDE 90 Flatbed Scanner
A window appears saying "unable to scan. Be sure there is enough space in the destination disk."
Your hard drive may be getting full...
Or the account (user name) you are using on the computer does not have enough "rights" to create the output file.
Assuming it is Drive C:
Open [My Computer]
Right-click Drive C: (one time)
and select "Properties"
In the [General] tab, locate and click on [Disk Cleanup]
The system will harmlessly "scan" your hard drive to try to free up space. It is not deleting or compressing anything.
When the scan is complete, a list will appear, place a check on:
Tempoary files, Temporary Internet Files,
(do not "compress" any files)
and click [OK]
Try your scan again.
This is a temporary fix. You need more hard disk space.
Sep 28, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Dec 18, 2008 | Canon CanoScan 8600F Flatbed Scanner
Problem with CanoScan Lide 500F
I would reinstall the driver first. Get the latest ScanGear and Toolbox from the Canon Website.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=11011
Do you have any other image devices such as a Multifunction (scanner,fax, printer) or digital camera attached to the computer?
Jun 30, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
Problem with Canon DR9080C scanner and Capture Perfect 3.0 softwere
Do you have enough disk space? Check if your C; drive has enough space. Normally C: is used as 'scratch area'. Try scanning intoa different location.
S. Mohan, Chennai
Jun 18, 2008 | Canon DR-9080C Path-Through Scanner
CanoScan 4400 won't scan
Try disconnecting other USB devices to determine if it is being caused by some other device.
Mar 21, 2008 | Canon CanoScan 4400f MultiFunction Color...
Canon 440f won't scan
I had exactly as described on my new 4400f scanner. Have resolved by uninstalling the toolbox software (it was at 5.0.1.2), downloading toolbox s/w from canon site, file name is S6A04mux.exe - toolbox 5.0.1.1 Installed this and all works from the scanner front panel
Jan 06, 2008 | Canon CanoScan 4400f MultiFunction Color...
Canon CanoScan 4400F Flatbed Scanner Logo
old marine
old marine
