Question about Comdial 8324S-PT Corded Phone
How do I silence the delayed tone when I press the numbers?
  • hpats Jul 10, 2010
    I want to remove the annoying tone each time I push the number keypad. Thanks.
  • 4,737 Answers
You cannot turn off the keypad tones completely, but you can turn down the volume from the volume control settings. If you turn it down to the minimum level, you'll not be able to hear the incoming voice when you use the speaker-mode during a call.
To change the volume level, press "Intercom" > "Speaker" and press the Down Volume Button and dial **5 or **7 (may vary the code from phone to phone) to set the selected volume level.
I am sorry that I can't give you the specific solution, but I've never seen and have done yet, and there's no direction on any user manual about disabling the Keypad Tones of a Comdial Phone. Hope this helps.
Good luck.
Thanks for using FixYa.
Posted on Jul 10, 2010
  • 2,335 Answers
I can help you with your Comdial 8324S LCD Speakerphone volume problem.
It sounds like you would like to dial a number (speakerphone, I assume) while having the numbers dial quietly while the call returns to an appropriate volume for conversation once dialed.
I do not see this specific feature in the Comdial 8324S Reference Manual.
What I do see are the following volume-related tips:
  • Once you have set an appropriate volume level for handset or speakerphone, press * * 7 to save this volume for all future calls. (You might consider setting this low enough for comfort during the dialing sequence, and then manually turn up the volume once the party has answered.
  • Pressing the speaker button turns your speaker on & off.
I hope that helps.
_______________________________________________
Comdial 8324S Reference Manual Download
Posted on Jul 09, 2010
The keyapd on my meridian telephone sets do not output any tone after a call is complete.
Key pads are for buttons, not dial tone.
When a call is complete it should be silence.
If you want tone then press Intercom or a Line or an Access code.
Dec 17, 2012 | NorStar Meridian Norstar T7208 Corded...
I have a SGH-c417 and need to find how to silence ring tone.
Hello and Welcome to FixYa!
The easiest way is to press and hold the HASH (Number sign key : #) when you are at the home screen. A 'Phone Silenced' message will pop-up indicating that its done.
Wiqi
Aug 28, 2011 | Samsung SGH-c417 Cellular Phone
How do I silence the keypad
To turn off the keypad tone just follow the steps below.
  1. While in standby mode, press on Menu
  2. Select Settings
  3. Select Sound Profile
  4. Press on the Sound Profile you are currently using
  5. From the Phone screen (Use the drop down arrow):
    • Press on the Keypad Tone drop down arrow
  6. Select mute
  7. Press on save
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
INCREASE RING TONES FROM 3 RINGS TO 6 RINGS
Generally (without knowing what phone yopu have) you need to press menu, arrow up to answermachine or TAM then press OK then arrow up to settings or TAM settings then press ok then arrow down to answer delay/ring delay/ring number press ok then use arrow keys to adjust rings, when on required number, press ok.
Feb 25, 2011 | Cell Phones
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
I need to silence an extension on the lucent 18d telephone
From ext. 10 or 11, press Feature 00, left intercom (twice), right intercom (once), Dial ext. number of boss' phone. Lights on the line button will indicate ringing state for that line:
Green light - Immediate ring
Fast Flutter Green light - No ring
Slow Flashing Green light - Delayed ring
Press each line key until Fast Flutter Green light appears.
Press Feature 00 to exit programming.
Jan 05, 2009 | Lucent PARTNER18 Corded Phone
How do i get the ringing tones back from silence mode?
press and hold the speaker icon on your main screen. It should go off the vibrating mode.
Dec 24, 2008 | Samsung P520
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
Uniden 900MHz phone model EX17960A
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
Each pause counts as a digit.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
number has been stored.
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
beep rapidly, and the phone will not dial.)
Nov 13, 2007 | Lands Phones
Comdial 8324S-PT Corded Phone Logo
89 people viewed this question
Top Comdial Lands Phones Experts
george  peters
george peters
k24674
Tom Chichester
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
