I have a new HP 2140 fax machine. I need to be able to send the same fax to 75 different people daily. How can I group the numbers so once they are entered into speed dial, I can hit one button and send them all. I know I can broadcast but I still have to physically dial the fax numbers. Is this machine capable of doing this. Again, I do not want to have to stand there and enter 75 fax numbers every day.
  • 2,272 Answers
You can send maximum 20 fax at once. the procedure is called broadcasting Broadcasting With Broadcasting you can have your HP Fax send your fax up to 20 fax numbers at once. The documents are automatically erased from memory when Broadcasting is finished. 1. Turn the document face down and feed it into the machine. 2. Press Menu repeated until ADVANCED FAX displays and press OK. 3. Select Set Broadcasting by pressing 􀀖􀀗 and press OK. 4. Enter the fax number. • You can enter 20 fax numbers into one job. 5. Press OK when the correct number appears in the display. • If you have more destinations, select Y by using 􀀖􀀗 and press OK when asked Another? Y/N and repeat steps from 4. • If you have finished entering all the numbers, answer N and press OK. The document will be scanned into memory before transmission. Speed dialing Your HP Fax has a built-in phone book that allows you to enter up to 100 names and numbers for faxing or telephone use. Once entered, you can dial the number by any of these methods. • One-Touch (first 10 numbers) • Searching the phone book through the Speed Dial button All numbers must be stored in the phone book before use. Store a number in the phone book Once in the phone book these numbers can be dialed using one touch buttons, or by searching the phone book through the Speed Dial button. 1. Press Speed Dial button repeatedly until New & Edit appears and press OK. The display shows Speed [00-99]>##. 2. Enter a two-digit number and press OK. Numbers from 00 to 09 will be used for One-Touch dialing. 3. Enter the telephone/fax number you want to store (up to 40 digits) and press OK. • If you want a pause between numbers (for example, when entering an access code where you need to wait for a second dial tone), press Redial/Pause. A P appears in the display. For a longer pause, simply press Redial/Pause again. • If you make a mistake while entering a number, use 􀀖􀀗 to move the cursor under the digit, then enter the correct digit. • Cancel will backspace delete in the field. • Holding down Cancel will clear the whole field. 4. Enter the name (up to 20 characters) and press OK. If you do not want a name, just skip this step by pressing OK. 5)Press Cancel to exit.
If you require user manual for your HP 2140 fax machine then please click on the link below:-- Broad casting is mentioned on page number 29 of the page on bottom it shows 32 but actual page is 29. http://static.compusa.com/pdf/HP-2140-FAX-Machine-Manual.pdf Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 09, 2010
Error 386
Hi Error 344,
Is telling you the remote end has hung up the call which means it may not be a fax number (you called a voice line number for example, you can confirm if it as fax by just calling the number on your phone if you hear the whistles of a fax then that's not the cause).
I'm not familiar with the HP model but if it is "Super Group 3" (you can tell this if the transmission speed is capable of above 14.4kbps) and you're trying to call an older fax the remote machine may not be able to recognise the "Calling tone" your machine is sending and so it hangs up. You can try to remedy this by temporarily disabling Error Correction Mode (ECM) in your machines fax set up menu this will disable the Super Group 3 capabilities of the fax and maximum transmission speed will be reduced to the older Group 3 machine. HP website recommends the following:
Error Code: 344, 345, 346, 347, 348, 349 ECM, 350 ECM, 351 ECM, 352 ECM, 353 ECM, 354, 355 Definitions
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jan 23, 2014 | HP Officejet 6600 e-All-in-One -...
Hp fax 2140 sends but does not receive faxes
check if the LINE is connected in the RIGHT JACK (LINE), not in the TEL jack. Check the panel or display if it is in (FAX OR AUTO) if the mod is in TEL it won't receive.
Dec 10, 2013 | HEWLETT-PACKARD HP 2140 Fax
How can I set up my answering machine with my hp 2140 fax
Use the fax setup wizard from the HP toolbox , when it asks if you have an answering machine connected to the fax line say yes. Or setup a distinctive ring from you phone company and set the fax machine to answer double rings only. Use fax setup wizard to do this as well.
Jun 14, 2011 | HEWLETT-PACKARD HP 2140 Fax
I have a 25 page document that must be faxed to several different numbers, on a daily basis. Is there a way I can fax the document to multiple numbers at one time? I am using a Canon Laser Class 2050 P -...
You can't send a fax to more than one number at a time since each fax call needs to be placed separately. But the machine allows you to automate the process by storing the numbers in speed dial as a group, and then sequentially sending the same fax to each of those numbers for you. Full details are in chapter 6 of the manual (available here if you need a copy).
Mar 24, 2011 | Canon Office Equipment & Supplies
Our HP 2140 fax under distinctive ring setting DRPD was answering under our Master ring (double Ring) until yesterday it switched inside somehow where it now answers regular phone ring instead of...
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
machine.
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Mar 04, 2011 | HEWLETT-PACKARD HP 2140 Fax
I need fax setup for Hp 2140 Fax or a manual
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3819105&lc=en&cc=us&dlc=en&lang=en&cc=us
Jul 24, 2010 | HEWLETT-PACKARD HP 2140 Fax
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
I need to know how to send a Broadcast fax to multiple numbers
This is right from the manual:
You can use the Multiple Send feature, which allows you to send a fax to
multiple locations. Originals are automatically stored in memory and sent
to a remote station. After transmission, the originals are automatically
erased from memory.
1 Press Fax.
2 Load originals face up into the ADF, or place a single original face
down on the scanner glass.
For details about loading an original, see page 5.1.
3 Adjust the document resolution and darkness to suit your fax needs.
See page 9.1.
4 Press Menu until Fax Feature appears on the bottom line of the
display and press OK.
5 Press the Scroll buttons until Multi Send appears and press OK.
6 Enter the number of the first receiving fax machine and press OK.
You can use speed buttons, speed dial numbers, or group dial
numbers. For details, see page 10.2.
7 Enter the second fax number and press OK.
The display asks you to enter another fax number to send the
document.
8 To enter more fax numbers, press OK when Yes appears and
repeat steps 6 and 7. You can add up to 209 destinations.
Note
You cannot use group dial numbers for another fax number.
9 When you have finished entering fax numbers, select No at the
Another No.? prompt and press OK or Start.
The original is scanned into memory before transmission. The
display shows memory capacity and the number of pages being
stored in memory.
10 If an original is placed on the scanner glass, select Yes to add
another pages. Load another original and press OK.
When you have finished, select No at the Another Page? prompt.
The machine begins sending the fax to the numbers you entered in
the order in which you entered them.
Manual - see page 54
Dec 15, 2008 | Samsung SCX-5530FN All-In-One Laser...
Multiple faxes
you can send it seperat only
Sep 19, 2007 | Canon LaserClass 2050 Plain Paper Fax
k24674
