Question about Goodman Heating & Cooling
I have a goodman heat pump. Can't read the model number. the ac turns off when it reaches the correct temperature but then doesn't come back on when the room temperature goes up. The only way to get it to come back on is to cut it off. Do you know what this could be or what we could check?
  • 2,272 Answers
Is your condensor fan motor stopping for any reason while calling for cool? no mention of how old unit is ? many times the fan may run for a few minutes or 30 min. or what ever amount of time then trip on internal overload. Check to see if you have a lot of dirt blocking the bottom of the ventilated condendsor motor if so blow out all vent holes on motor and oil motor if equipt.Double check the compressor terminal hookups for burnt wires remove clip and look at the 3 wires ,are they tightly on the compressor and not rusted and loose.The thermostat and temperature sensor is not functioning properly.As it should come on when there is temp rise but they are not functioning properly so the ac is not coming on. Check out.Thanks.
Posted on Jul 09, 2010
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
I HAVE A GOODMAN HEAT PUMP, MODEL AR30-1. I switched off the heat pump at the stat and the elements seem to be running heating up the unit... Also what is the brown wire coming from the wiring harness for...
The brown wire on a Goodman is tipically for the emergency heat option on your heat pump. First thing I would check is making sure it is wited correctly. Verify your stat is heat pump capable. Many of the cheaper stats only work for ac or just a heat pump. Anything beyond that would be a more serious electrical problem and should be looked at by someone with the proper training and tools.
Feb 11, 2011 | Goodman Heating & Cooling
Furnace will not shut off after the setting is reached. have changed thermostat. Temperature reading goes down on thermostat, furnace still runs. Model : Goodman furnace,gmh95/gch9
Check if your thermostat is set on 'o fan' setting.
If it is, trey to set it on 'Auto-fan' instead.
since it seem as if the heating does go off,only the fan may be running continuously.
this is possible if the thermostat is incorrectly set or installed.
good luck.
Jan 30, 2010 | Goodman GMS90703BXA Heater
No AC from older Intertherm split system
It sounds like you are low on refridgerant. Double check to make sure both fans and the compressor are running. If so then you have a refridgerant problem.
Aug 29, 2009 | Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Electric furnace runs but won't shut off on heat setting
I would insist that Sears either have a Senior tech come out and fix it or return it to the state it was prior to them touching. Then call some one else. Have them involve the Goodman rep in your area.
Goodman Air Conditioner not heating well...
Heat pumps in cold climates suffer a number of limitations stemming from the fact that they are designed for air-conditioning applications. As climates become cooler and heating becomes more of the primary HVAC function, one may find that conventional heat pumps lose capacity and do not satisfy the load of the conditioned space. In colder temperatures, a conventional system’s need to defrost can further detract from heating performance. The use of resistance heat or fossil fuels to supplement or replace the vapor cycle. The additional use of supplemental heat to temper cold air blowing into the space during defrosts. As it gets colder outside, the delivery air temperatures inside begin to fall when no supplemental heat is being used. Supply air temperatures that are warmer than the return temperatures add heat to a space, but discomfort occurs when these supply temperatures drop below skin temperature. The air movement can feel cool or even cold. While the heat pump may be operating exactly as intended,the consumer will desire a more comfortable environment.
Jan 18, 2009 | Goodman CKL49AR49 Air Conditioner
3ton heat pump googman 14 seer
Give me the model numbers on the heat pump and the coil, I would expect its a really poor match.
Nov 11, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
