Question about Amana 7M11TA Air Conditioner
Why is my amana floor air conditioner leaking water
  • 50 Answers
SOURCE: amana portable air conditioner
you need to empty the drain pan every couple of hours depending on the humidity level
Posted on Jul 21, 2011
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Posted on Jul 15, 2007
22yooper
  • 828 Answers
SOURCE: rv air conditioner leaking
In each of these cases I would check for proper connection of the return air vent to the A/C from below. Static pressure from insufficient return air could cause negative pressure to hold back on condensate drainage. when the unit is shut off the pressure becomes equal allowing water to drain. Also check air filter and clean if found necessary.
Posted on Jul 18, 2008
SOURCE: We have a 2007 Amana
That is a normal function of the air conditioning. Nothing to worry about, it is removing humidity from the air.
Posted on Jul 25, 2008
  • 2976 Answers
SOURCE: Air Conditioner in wall not window like hotel unit, leaks inside
Open the cover. In the bottom drip pan, there is a hole that is clogged. Just unplug it and it will drain.
Posted on Jul 07, 2009
Air conditioner leaks on floor
Sounds like the outside drain is stopped up.
There should be a tube coming out of the firewall near the passenger floor.
Jul 29, 2012 | 2001 Cadillac DeVille
Amana D965e-e dehumidifier leaking
I encountered a similar problem (using the bucket, but still getting water leaking onto the floor) with my 970E-E. The problem is a design flaw. If the bucket is not firmly pressed into the dehumidifier, there is a slight air gap between the bucket and the dehumidifier on the left side. Within the gap, warm moist environmental air cools. Water condenses in the gap and pools up at the bottom of the bucket shelf, eventually spilling over onto the floor. You can check and see if this is your problem by pulling out the bucket and inspecting for droplets along the left side of the bucket shelf. My solution was the bungie the bucket into the shelf firmly so that there is no air gap.
May 29, 2012 | Amana Dehumidifiers
Midea portable air conditioner leaking water from bottom
Do you have it tilted back slightly towards the outside? It will drain on the inside if not tilted properly.
May 05, 2012 | Amana Heating & Cooling
Amana ap077r IS LEAKING WATER FROM THE BACK
Find the evaporator condensate drain and check that it is routing water into the pan
Jun 22, 2011 | Amana AP077R Portable Air Conditioner
Water leaking
depends on where its leaking. Air conditioners create condinsation it is a by product of it function. the water should drain thru a drain line and either go into a floor drain a pump or outside. if its leaking all over your floor it may be a clogged drain. If its not working well too then it may be freezing up and causing excessive condinsation beyond the drain area. you should make sure your filter(s) are clean and the drain is clear.
Sep 18, 2009 | Heating & Cooling
My air-conditioner is leaking a lot of water onto the floor.
You may jst have a stopped up draon or drain pan. If you can get to thesmall whole that it drain out of. **** it out with a shop vac. If you have one. Russ
Jul 26, 2009 | Pelonis KCD-25YI Air Conditioner
Water leaking all over
The water leaks all over the floor instead of running into the water containner. if that is right then your condenser drain pan tubing is blocked or the pan is rusted out that cause the water leaks all over instead of running down the tubing into the water containner . You've to dismantle the panels to get into this condenser drain pan to have a good clean out . Hope this will help . God Bless.
Jul 23, 2009 | Heating & Cooling
Leaking evaporator home ac NEW Amana unit
Friend,
Happy to assist you!
Why are you doing it?
You have a new warranty, call service and let them correct it!
You need to call service !!!!!!!!!!!!!
Aug 29, 2008 | Amana Heating & Cooling
We have a 2007 Amana Portable Electric Air Conditioner 7000 BTU. We can't find the manual and it is leaking water out the back. How do we fix this?
Jul 04, 2008 | Amana Heating & Cooling
Amana 7M11TA Air Conditioner Logo
101 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
