Question about Mitsubishi WD-52531 Television
I have a Mitsubishi WD-52531 television. We changed the bulb and now it is shutting itself off. Should we change the ballast?
  • 98 Answers
SOURCE: Mitsubishi WD-52525 Lamp ballast
Contact Mitsubishi Parts themselves, 18005537278. They are very friendly.
Posted on May 15, 2008
ZaneD
  • 41 Answers
SOURCE: Mitsubishi 52725 52525 Red Light turns on
the problem might be the thermal sensor on the light engine. with all the work you have done on this i would suggest taking a look at the thermal sensor. these are known to go out.
Posted on Apr 19, 2009
mbelectronic
  • 147 Answers
SOURCE: Need to replace the ballast on a 52HM94
the ballast is a small rectangular board.it is very easy to change.remove the lamp and you
will see a plug where the lamp plugs into.remove the two screws on that plug.then
remove the 4 screws holding the ballast in.remove the ballast and install the new one.
Posted on Jul 17, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Wd-52628 bad lamp or bad ballast?
you cant - unless you have another tv to test it in. May be a ballast or the cooling fan for the lamp is not working.
Posted on Feb 03, 2010
eddiepeezy
  • 130 Answers
SOURCE: Mitsubishi WD-52531 not working after replacing
Check to make sure the lamp is in correctly and that you've closed everything up properly. If you don't close the cover, the sensors will tell the computer in the TV that the door is open and won't let the TV turn on.
Other than that, could be a bad lamp or bad ballast.
Always buy OEM lamps, or better-than-oem equivalents! Philips lighting is the best lamp manufacturer out there for these TVs. They invented the thing!
Buy from Authorized distributors, and don't buy the "cheap" stuff. savnig 20 bucks will cost you more in the long run--believe me!
Posted on Feb 05, 2010
Mitsubishi wd 57734
Hello, it sounds like the "g board" or power supply has gone bad. Any "code blinks" when it shuts down?....tks
Oct 31, 2013 | Televison & Video
WHERE CAN I FIND THE BALLAST IN THE MITUSUBISHI WD 52532 MODEL
hint: the two pins the lamp plugs onto go directly to the ballast which is really a power supply for the lamp.
not clear from all you have said if ballast is the problem===these sets had a lot of issues; anything, even too much dust on the fans inside will shut it down...........
Mar 26, 2012 | Mitsubishi WD-52531 Television
The lamp light is blinking orange and we just replaced the lamp! on model WD-52531
You may have not plugged the lamp in fully or have not put the lamp door back properly. If you have done this properly and have the blinking problem then you are likely to have a bad ballast. This ballast supplies the voltage to light up the lamp. But first look on the front of the set for a small push button that says "system restore/reset". Use a ball point pen to press.
Jun 28, 2011 | Mitsubishi WD-52531 Television
I changed the bulb on my wd-y577 it turns on for a few minutes.Then it shuts down the bulb and status light comes on
CK the Lamp Fan if it stops running when Lamp starts to light set will shut off.
Ballast board is what powers Lamp on.
Oct 28, 2010 | Mitsubishi WD-Y577 Television
Mitsubishi WD-52531 not working after replacing the buld.
Feb 05, 2010 | Mitsubishi WD-52531 Television
Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Jul 18, 2009 | Mitsubishi WD-52531 Television
Lamp lite
Does the lamp indicator stay yellow, or does it turn red?
May 17, 2008 | Mitsubishi WD-52531 Television
Mitsubishi WD-52531 Television Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
