Question about Fender Squier Std Strat Mn Car
15th fret sounds completely flat
Depresing the 3rd an 4th string
    President:
  • 1,138 Answers
Here is a link to the instructions you need:http://www.fender.com/support/stratocaster.php Pay particular attention to Intonation Roughing It Out section. Hope this helps.
Posted on Jul 13, 2010
I have a set of 11-48 12string i have never strung a 12string guitar before.can you tell me what string goes in what hole? 48 40 30 26 20 16 14 14 12 11 11 9
the Heaviest string of each string pair is placed at the top (closest to your nose). In fact, if you look at the nut, (the notched thingy that spaces and holds the strings at the right spacing up by the tuning pegs) the notches in nut are wider than the paired string for this reason. That may not be true on all 12 strings but it is on mine. So the typical arrangement is heavy string, matching string. Heavy String, matching string. Except on the bottom 3 pairs where the actual string thickness can be the same. One caution note here....when tuning a 12 string, tune it a whole step lower. So rather than tuning it at EADGBE, tune it at DGCFAD then use a capo on the 2nd fret to bring the tuning up to EADGBE.
The reason for tuning a whole step lower is because on the top 3 pairs of strings you normally tune the thinner string an octave higher to give that 12 string sound. So if you start tuning at EADGBE, those thinner strings for the top EAD strings are going to be pretty tight and they will snap. So much safer to tune a whole step lower and just use a capo!!! Good Luck
Nov 13, 2017 | Music
How change strings gibson guitar?
One of the best was to keeping your guitar in tune, is to also string it correctly and use new strings . Make sure the first winding of a new string around the tuner post goes over the exposed tip of the new string. The rest of the windings go under the exposed tip of the string. This will keep the string clamped firmly in place. Use 4-5 turns around the post for unwound strings, 2-3 for wound strings, in a downward spiral towards the bottom of the post as shown in the photo.-Tom, 30yr player.
Apr 15, 2016 | Gibson Les Paul Studio Electric Guitar
My 3rd guitar string sounds bad
Get it a repare at guitar center they have a pack of guitar strings for 5-10 Dollers they are located in Oregon Washington cailfoina if you relly want a cheep guitar that sounds good get bc rich or finder or eipcphone your guitar strings are probley getting old you have to buy a certain brad of stings that well last a year and if you need tuneing you can download an app for online tuning or you can type in online guitar tuneing I hoped this helped give me a message if you need more
Nov 25, 2012 | Dean Guitars Dean Ml Xm Electric Guitar
The 6th, 5th and 4th strings are too near the twelve fret and sounds terrible on Takamine TH90. This is more severe in summer. I know the guitar has a bar inside the wood, but I do not know how to adjust...
You best take it to a shop for setup. The truss rod USUALLY has an adjustment in the sound hole or under a little plat at the neck. You can easily cause damage if you are unfamiliar with the adjustment. It is possible that there is a problem with the bridge as well. Having the guitar setup by a professional is safest thing for you to do.
Jun 02, 2011 | Takamine TH90 Hirade Concert Classic...
B string flat up to 4th fret
You need to set the intonation. There are videos on Youtube on how to setup a guitar. Avoid doing anything to the truss rod. Search YouTube for "guitar setup". If it will not setup, you might need to replace the string.
Jan 31, 2011 | Epiphone Les Paul Special II Guitar...
Guitar truss rod dilemma
The truss rod must be too slack then.
Is the sound ok? Does it play ok?
In it's current state the truss rod is doing nothing.
If the guitar is sounding ok and playing ok, then the next time you change the strings pull the truss rod out and throw it in the garbage.lol
Seriously though...just pull it out and put it aside.
If,however,the guitar is not sounding ok then try tightening it.
If you're unsure about how much to tighten it then I suggest taking it to your local music store for help with that.
Sep 21, 2009 | Music
No the truss rod is usually in more than that. Take it to a reliable Musice Store and they shold be able to adjust it for you.
Sep 21, 2009 | Boss Micro BR Digital Recorder
No instructions for a yamaha erg 121 c electric guitar
i don't really know what instructions you expected, although you should have received something for the tuner and amp. I suspect that you are new to playing the guitar, as, I don't wish to sound disrespectful, you would know what to do! So first, and again I hope not to sound like I'm treating you like a dummy, plug the guitar into the tuner input. Or if It's a piezo tuner clamp it to your headstock. Most tuners are now automatic so it should pick up on the string you are striking.Repeatedly pluck the same string til the tuner changes colour, or flashes, or some other indication to tell you the string is at pitch. Repeat the above for all 6 strings.
Then plug the cable into the amp input, switch it on, and bugger about with the controls til you get a half decent sound. ( thats what the rest of us do).Don't expext too much from this package, it is budget level, but of quite good overall quality.hope this helps
Feb 05, 2009 | Yamaha Electric Guitar
Roland GK-2A pickup. g string does not respond
I have the same problem. Only the 1st, 3rd and 5th strings respond. This is not a sensitivity adjustment. The unit does not see the strings. I called Roland and was able to purchase just the pickup itself rather that the entire GK-3. The pickup was about $35 but took 4 weeks to arrive. When it finally got here I was excited. It was not difficult to remove the old and replace it with the new. I plugged it in. NOTHING CHANGED! I believe and hope it ti the 13-pin cable. I have read where these cables are just poorly made and many users have spent a considerable sum on the cable, most recommending having one in reserve always as they are sure to go out.
Dec 31, 2008 | Music
Fender Squier Std Strat Mn Car Logo
243 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
