Question about Garmin Nuvi 660 GPS Receiver
My internal speaker doesnt work - Garmin Nuvi 660 GPS Receiver
  • Garmin Master
  • 2,130 Answers
Please see this link:
http://www.sharc.net/gps_audio_repair.htm
- Jim
Posted on Jul 21, 2010
Testimonial: "It probably was damaged due to heat, thanks I guess Ill send it in to Garmin"
  • SHARCNET-USA
    SHARCNET-USA Jul 26, 2010
    You can send it to us if you like. Compare prices. Good luck!
How to repair Icom IC-M700 HF transeiver?
Does it have an external speaker plugged in the back? If so try unplugging it see if the internal speaker works, if it doesnt have an external speaker plugged in try one, maybe the internal speaker went bad from moisture.
May 28, 2014 | Icom M700 Pro - IC AT-130 automatice tuner
Only 1 side of my dr dre detox is working
THE INTERNAL WIRE CONNECTING BOTH HEADPHONES IS BROKEN. THIS PROBABLY HAPPENED WHEN TWISTING ONE OF THE HEADPHONES TO HEAR ONLY THROUGH ONE OF THEM. TRY FEEDING EEACH HEADPHONE INDEPENDENTLY WITH ITS OWN CABLE USING ONE OF THOSE PLUGS TO SHARE MUSIC FROM SAME SOURCE.
Jun 22, 2012 | Beats By Dr Dre Beats By Dre Detox
There is no sound. I have connected it to my new Toshiba laptop
Hello there,
When you plugged it into your laptop, turned it on and increase the volume, do you hear only a humming sound from the speakers? Try to plug the speaker to an mp3 player as well to test if it still doesnt give out any sound. If it still doesnt, then your speaker must have a wiring connection problem inside that needs resoldering. Here I supposed that your laptop's internal speakers is working and is able to work with other audio devices like a headset or an earphone.
Dec 20, 2010 | Insignia 2.0 Speaker System (2-Piece)
I have an HP Pavilion 6113US and the internal speaker has just stopped working. I can listen via the headphone jack fine. I have used System Restore and re-flashed the bios but the internal speaker still...
Hi. I would suggest updating the Audio drivers for your machine if this doesnt work, this is probably a hardware issue for the internal speakers because when you plugin a headphone it would work so its not with the motherboard or with the softwares for your machine. So consider replacing the built it speakers or try calling HP support for your issue if your machine is still under warranty and they would help you fix your issue without any charge. Hope this Helps
Jun 09, 2010 | Computers & Internet
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
The Sound doesnt work,
your internal speakers then has went bad and will have to be replaced.
Jul 15, 2009 | Computers & Internet
Connected to computer but not working
try to connect it at the back of your pc in the clor geen port... and disable your internal speaker...give me feed back if it doesnt work and discribe the problem specificaly...
Jan 11, 2009 | Harman Kardon SoundSticks II Computer...
Sound Won't Work on Dell Computer
Go to Control Panel and go to sound and audio devices. It should have the name of the speakers you are using. If it doesnt then the speakers might not work on that PC. Get a new set of speakers, and try again. It should work on the new ones. If it doesnt, get it checked at PC World or a PC repair store to get it checked, as the problem will be internal in the PC. Hope it works.
Sep 15, 2008 | Dell Computers & Internet
Reciever Problem
hi, its definetly an internal problem, commonly in the output section, usually its a capacitor or an transistor which is leaky or short. which causes the overload, so u will need a techinical hand to get it resolved.
Feb 12, 2008 | Audio Players & Recorders
Garmin Nuvi 660 GPS Receiver Logo
76 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
