Question about HP Officejet 6310 All-In-One InkJet Printer
6310 on wireless LAN
Can this printer be set up to operate on a wireless LAN ??
  • HP Master
  • 6,487 Answers
Sorry to say but this printer don't have a wireless capability, it only works on Hi-Speed USB , Ethernet 10 Base-T/100 Base-TX. But if you want to make it wireless you can use a wireless print server from different manufacturer like Linksys WPS54G.
Posted on Jul 09, 2010
Ink jet wireless printer says its printing then it shows an error and will not print.
Hp Office jet 6310 is not a wireless printer. Now if you will tell me that is it connected through Print Server?
Apr 13, 2011 | HP Officejet 6310 All-In-One InkJet...
Hello, I lost the software for the hp office jet 6310,and also the manual,and dont know how to make it work wireless.
First download driver from below link. Click here Then install it in computer. Make sure your in printer settings wireless is enable .Also make sure printer ip address and computer ip address of wireless are in same subnet and gateway. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 29, 2010 | HP Officejet 6310 All-In-One InkJet...
Does the 6310 Officejet all-in-one have wireless capability?
From the manufacturer's web-site, download the Setup Guide:
http://h10032.www1.hp.com/ctg/Manual/c00633795.pdf
Do you see any instructions on how to make a USB connection?
a wired-Ethernet connection? a "wireless" connection?
Aug 24, 2010 | HP Officejet 6310 All-In-One InkJet...
Please what is the steps for correcting my wireless printing, my vista/laptop cannot see my printer to print wirelessly any more I have an hp 6310 all in one. There is another computer in the house that...
To be able to set up wireless printer configuration, there are three basic items that you need to have. They are a high-speed broadband Internet connection (with modem), a high speed wireless router and wireless network adaptors. These three items will be used in setting up the wireless printer. Assuming that there is already an existing network in the home or office space, then all that is needed to do to make the printer available in the network through the operating system’s networking wizard. If not, then the network must first be established, only then the printer will be made available through that network. get more information and help for Wireless Printer Configuration .
Apr 15, 2010 | HP Officejet 6310 All-In-One InkJet...
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
Where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
Double-click on the taskbar.
2 Select your wireless LAN adaptor and select [General].
3 Select [On] for [Switch radio].
4 Select [OK].
The icon will turn to or ��
Oct 04, 2009 | Panasonic Toughbook T2 Notebook
Can't get 6310 to find laptop and allow wireless printing
you have to setup the network on the printer first click setup then go to network then wireless setup wizard once you do that insert the cd and add a device if that doesn't work it may be a firewall issue disable every firewall on your pc if it still wont find it it may be the firewall on your router
Jun 17, 2009 | HP Officejet 6310 All-In-One InkJet...
I need to install my new HP Officejet 6310 and set it as the default printer . I don't have a Installation CD Rom
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER WITHOUT CD-Rom
STEP 1: In your computer window click the Start button and select the option Devices and Printers.
STEP 2: A new menu Devices and Printers appear on the screen. Then click the option Add a printer.
STEP 3: After clicking the Add a Printer option two options appears on the screen.
Add a local printer
Add a network & wireless or Bluetooth printer.
Select the option that suits to your printer
STEP 4: If your printer is not a wireless then select the Add a local printer and select the option Use an existing port then click next.
STEP 5: Scroll down to select the HP in the manufacturer section.
STEP 6: Select your Hp printer model in the printer section then click next.
STEP 7: If your model number is not present then click the windows update it will automatically add your printer model.
Note: You must need internet connection to update the printer model to your computer.
STEP 8: Then click next and finish.
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER FOR WIRELESS CONNECTION:
Add a local printer
STEP 4: Select the option Add a network, wireless or Bluetooth printer and click your printer name and address.
STEP 5: After the HP officejet 6310 printer installation of your wireless printer next step is to add your printer name and click next.
STEP 6: Set default printer as your HP Officejet 6310 printer and select the option print a test page.
STEP 7: A new popup window appears on the screen, then close it and finish.
Jun 11, 2009 | HP Officejet 6310 All-In-One InkJet...
Printing wirelessly using ethernet from printer to router.
You need to get IP address from the printer, and enter it in the router. Or sometimes the software will do it on installation
Apr 24, 2009 | HP OfficeJet 6310 All-in-One Printer...
Wireless laptop not printing
Indeed, you don't need the print server. Since your HP 6310 already has an integrated network port, you may setup and use it on your laptop the same way you do with your desktop. If you can browse the Internet wirelessly with your laptop, you should also be able to print.
Jan 20, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
HP Officejet 6310 All-In-One InkJet Printer Logo
153 people viewed this question
Seeker5211
Seeker5211
