Question about Compaq Presario 5000 PC Desktop
Is there any way to retrieve a password if you dont have the reset disk and not loose all information on hard drive
    Master:
  • 515 Answers
You can back up the data by moving the hard disk to another computer if you don't meet any permission messages when doing so. Or if your data is not on the system partition, you may try reinstalling without re-partition and format anything - install it on the original system drive such as C: drive.
Posted on Jul 09, 2010
How do i remove a built-in HDD password?
If it is the password that has been firmware locked, you cannot. This is to stop people who steal laptops from accessing data
If its a BIOS password, access the bios by pressing ( I THINK) F2 or F1 or Del at start up, navigate through the BIOS screens until you find SET Password and remove it
Dec 25, 2010 | Toshiba L305-S5955 Notebook
Hard disk not detected - Need to retrieve data
If it is your system drive (C:)
You can remove it and try connect to another computer (internal or in an external caddy).
Usually you can get the information you need like this.
Jul 23, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Safeboot corrupted (error 92h)
Check the BIOS setting to see if the hard disk is detected. If not either the hard disk controller or the hard disk is faulty.
First thing I would try is to remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an external hard drive and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services.
Jun 24, 2010 | HP EliteBook 2530p Notebook
Simpletech 250 GB Pininfarina was knocked on the floor
oped it, maybe loose cables or connections. or the worst case, a faulty hd. ticking sound means bad drive, cannot read disks. retrieve data? the better chance will be a recover technician, dont try anything else, will turn a worst problem.
Jun 02, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
I forgot my Toshiba Satellite A215 S4747 Built-in HDD1 User Password
U can reset it in BIOS.....If not then take the CMOS battery of the lap outside and then place it in place. But if u dont know the hardware parts correctly please go to the service center as they will clear the problem for U
Thank You
Please rate me as it will be just one CLICK
Don't find fault, find a remedy. - Henry Ford
Oct 23, 2009 | Toshiba Satellite A215-S4747 Notebook
Dell Jukebox is stuck in Rescue Mode
did any of this stuff actualy work?? because i am having the same problem with mine the only thing is as long as i've had mine i didn't even know where the reset button was.
Mar 23, 2009 | Dell DJ MP3 Player
NEED PASSWORDS TO ACCESS HARD DRIVE
Sharon, you have a extremly difficult problem.
Why is the laptop in for repair, is the laptop faulty, how do you know the hard drive is faulty when you cannot start up the laptop?
It appears that you have or someone has set up a power on password and possibly a password protection on the hard drive.
If you hard drive is faulty it is highly unlikely that you cannot retrieve any data off your hard drive with or without the passwords.
IBM ThinkPads laptops store the Power On password on an EEPROM chip and removing the BIOS battery cannot clear this password. there are no backdoor passwords that you can use. The passwords are used to prevent unauthorized access to the laptop and its data.
If there isn't a password on the hard disk, and the hard disk is not faulty, you can remove the hard drive and connect it to a working computer to read and copy off your data. I suggest you connect your hard drive using a USB hard drive adapter and connecting it to a working computer's USB port.
IBM states that if you don't know the Power On password, therefore you cannot get into the BIOS to remove the password, and you need to replace the motherboard (this is not cheap).
There is a way to hack into the laptop, it required some electronic experience to build a reader device, dismantle the laptop, solder it to the EEPROM chip, connect the output to a working computer, run a reader program, locate the password from this data, unsolder the wires, put the laptop back together and boot up and enter the password.
For detailed information go to www.allservice.ro/forum
I have successfully removed these passwords, it is a lot of work, and needs to be tackled by an experienced person.
Best of luck.
Dec 18, 2008 | IBM ThinkPad T23 2647 Notebook
Brand new hp pavilion dv2839tx entered pass word & it`s not reconised,try to reset password,informed to use floppy disc or usb flash drive & try again,i have done this with blank floppy disc,still...
Let me help you with that concern!
First, the computer asks you for a Password Reset Disk right? And then you inserted a BLANK Floppy Disk since you dont have a Flash Drive. But here is the thing, the computer is asking you a "Password Reset Disk" and in order for you to do that is, after you created a password into your account at your computer, the computer suggests to create a reset disk by inserting a floppy drive or a flash drive. And what the computer is doing is copying the password data into the floppy drive or to a flash drive. So inserting a blank floppy drive will do nothing on recovering your password. You need a password reset disk, but then again i think you did created a reset disk, so what you can do is to Reinstall the Operating System. I know your files are important but that is the only last resource that we can do. My suggestion is just back up all your files by inserting you hard drive into another laptop or you can just call drivesavers. You may visit their website at www.drivesavers.com and this is only a tip if still want to backup your files. But the resolution is still reinstalling the operating system.
Thanks!
I know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Jul 26, 2008 | HP Computers & Internet
Hdd password blocked
There are a number of methods that can be used to bypass or reset the BIOS password, like
  • Using a manufacturers backdoor password to access the BIOS
  • Use password cracking software
  • Reset the CMOS using the jumpers or solder beads.
  • Removing the CMOS battery for at least 10 minutes
For a free software to reset BIOS Click Here:
For more information please check out my solutions, i have allready given some tips on this issue.
Thanks
Iqbal
Mar 31, 2008 | Computers & Internet
External hard drive -help please?
Hi
Have you checked it on other pc ? If yes then your hard disk is corrupted you lost partition information but dont worry u can retrieve your data by getbackdata for NTSF. Its able to retrieve about 98% of data or other is Acronis Disc Direct Suite, the same reliable and really working tool to restore information. It really restored ALL files in lost partition
After using these tools just format your hardisk and it will work dont worry
Regards
Balisonu79
Feb 14, 2008 | Sony 1.44MB Floppy Floppy Drive
Compaq Presario 5000 PC Desktop Logo
46 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
