Question about Frigidaire 20.5 Cu. Ft. Top-Mount Refrigerator - Black
Light wont go on in refrigerator
New light bulb will not go on. Problem occurred before but then the light resumed for 2 more months.
The button that moves when the door opens opens and closes fully, but does not affect the light.
We recently had power outages that took 7 hours to fix.
The Frigidaire (freezer on top) is over ten years old.
The owner is past 74; owner just went back and tried the new bulb again, this time screwed it in harder. ON CAME THE LIGHT!!!
  • 1314 Answers
SOURCE: Frigidare side by side FRS202RG freezer cold, fridge side warm (coils frozen)
your having a defrost promblem either the adc-auto defrost control board is bad or the defrost termination thermostat is bad or the heater is bad thats rare but does happen if you will open the refridgerator door and get me the model number off the serial plate on the toop of the compartment just look up when you open the door then let me see if it has an adc or timer i can reply and be more spefic about fixing your promblem hold my rating till we are done ok
Posted on Mar 30, 2008
SOURCE: Condensation on refrigerator front btwn top freezer and refrigerator doors
I have the same problem with my frig in the basement. I get condensation and resulting mold on the top outer surface and related areas. This is from the surface being cold, with resulting outside moist air condensing on the cold surface. Best solution - spray/wipe the surface with a bleach and water solution, let it soak a few minutes, then wipe off with a rag. Add a drop of dishwasher soap to a mixture of roughly 4 parts water to one part bleach. Repeat if necessary. Do this as often as the problem seems to creep up again. Good luck!
Handyman in NJ
Posted on Oct 11, 2008
meBNme
  • 334 Answers
SOURCE: Refrigerator door won't shut
Check to see if the door gasket has forzen water that is preventing it from collapsing like it should and wedging the door open. This would most likely be on the hinge side of the door.
Also make sure the gasket is not bent or warped and binding as it closes.
Let us know if you find nothing wrong there and we can look further.
Posted on Dec 07, 2008
tborn6
  • 700 Answers
SOURCE: Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Posted on Mar 29, 2009
  • 105 Answers
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
Posted on Apr 17, 2009
Canon mx320 printer error has occurred 5200
You need to reset the printer. Try the steps:
• Plug in the power cord of printer.
Press Resume button 2 seconds
then press the power button until the green light on (when pressing the power button,Resume button)
• Then release the resume button, but do not release the power button.
• While the power button is still pressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange.
• Release both buttons simultaneously.
• Led will blink briefly and then will glow green.
• And the computer will detect new hardware, just ignore ...
• Press the power button again then the printer will flash and. Printer is ready for use.
Feb 06, 2013 | Canon PIXMA Office Equipment & Supplies
Printer error 5200
Well it seems like the waste ink pad error. You can override it but it will need changing or the printer will leak ink from the pad eventually.It needs a service now and the waste ink pad changing but you can reset it yourself by following some simple steps -
1. Plug in the power cord of printer.
2. Press Resume button 2 seconds then press the power button until the green light on (when pressing the power button, Resume button).
3. Then release the resume button, but do not release the power button.
4. While the power button is still pressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange.
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow green.
7. And the computer will detect new hardware, just ignore
8. Press the power button again then the printer will flash.
Check your printer again now it's ready.
Regards
May 07, 2012 | Canon PIXMA MP610 InkJet Printer
An error occured to my printer says ink absorber almost full. how to solve this?
Hi there!
To resolve this problem, you will need to reset the printer. To do this, follow this simple stes:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope this helps!
Apr 10, 2011 | Canon PIXMA iP2000 InkJet Printer
Always time sow Error number; 5200 A printer
Here's How to Reset Canon IP2770 Error 5200:
1. The printer is turned off and plugged the power cord.
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Mar 16, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Have got an error 1500 and it wont reset
Hi it may be waste ink full
1. Turn off printer
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Can I do something myself when this shows up? Error Number : 1700 The waste ink absorber is almost full. Press the printer's RESUME button to restart the printer. An error may occur if you continue to use...
Try to do this:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Oct 07, 2009 | Canon i80 InkJet Printer
Tank full.
Before doing this make sure that the waste pad inside your printer was drain and clean or must replace first because if not, overflow will occur. This is why it happen to your printer,its a protection.
steps:
1. Turn off the printer (don't unplug)
2. Hold Resume button and press the power button and hold (don't release the buttons)
3. While holding the power button release the resume button.(Don't release the power button)
4. Now press the resume button twice and then release both the power and resume buttons to get in the service mode.
5. When the LED light is green, press the resume button 4 times. ( When the resume button is pressed, the LED lights alternately in orange and green starting with orange.
6. Press the power button to perform reset.
7. Press the power button to exit service mode.Good luck and God Bless!!
Sep 23, 2009 | Canon PIXMA™ iP4300 InkJet Photo Printer
My printer needs to have the waste ink reset how do I do this
You can try this....
  1. Turn off Canon S300, S400, S9000 Printers
  8. Your Canon S300, S400, S9000 Printers should respond as normal.
But this happens because the waste tank is full. You need to locate it and use a paper towel to absorb the waste ink. Whenever the printer cleans itself ( when a new cartridge is installed, for example) some ink is cycled into this chamber. So if you reset and it is full, overflow may occur.....
Jul 23, 2009 | Canon BJC S300 InkJet Printer
Pixma ip 3000 power on all the time no functions. cannon
1. Turn off printer
Nov 29, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
AAAGGGHH! Cannon i9100 printer WON'T Print...can't get help
jast go in control panal in parinter doble cilck on printer icon cancel all the print documets try this mthrod & tell me what happen
Feb 26, 2008 | Office Equipment & Supplies
Frigidaire 20.5 Cu. Ft. Top-Mount Refrigerator - Black Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
