Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
My saltwater system produces chlorine but disappears fast
My saltwater system produces chlorine but disappears with in 8 hrs.
I run the chlorinator at night for 5 hrs so these are the readings I get at 7 am, in the morning
Bromine is at 5
Free Chlorine is 5
ph is 7.5
total alkalinity 120
Now when I get home at 5pm I check reading again and this is what I get.
Bromine 0
Free clorine 0
ph 7.5
The pool is covered and is not being used yet.
Thanks for any help you can give
  • 297 Answers
First of all your problem is a few things combined.
First lets learn what consumes chlorine
Heat,sun,rain,sun tan oil 3 of swimmers
you may need to run your generator 12 hours some nights it all depends on what kind of day it was and what the chlorine was to start with
Also if you do not have your salt as close to 3000ppm as you can then you are also not generating enough chlorine even if you are not triggering an alarm for low salt
you can not be below 2800 and no higher than 3800ppm
a test kit is available get the strips that reads #'s not the color strips for salt reading
Also you should be using a chlorine stabilizer to help hold the chlorine level this is only a help situation. it will not completly remidy your chlorine level going low if all the elements I mentioned are happening at the same time
Also be carefull not using the pool that is the worst thing you can do. You may go green quick without people in it stiring it up
I also recommend you use a non foaming algaecide every 5-7 days just follow directions for your gallons of water
By the way bromine tests are really not for pools they are designed to work with the hot water and chlorine level of a hot tub
your ph is fine, about in the middle alkalinity is what drives your ph so worry about the ph level and chlorine and you are good to go
Posted on Jul 09, 2010
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
How long should you run system
Always start high and work your way down...You want to maintain a 3ppm chlorine level..
Start by running a 12hr pump cycle with 10 hrs of chlorination... Check you chlorine level after 2 days and try to hit a target of 3ppm and after that, lower you cycle to maintain that level. For small pools, could be as low as 6 hrs pool pump, with 4 to 5 hrs chlorination??? I hope this helps you.. Good luck..
Aug 27, 2011 | Intex Automatic Salt Water System for ...
Ok i have the intex 1600gph sand filter saltwater combo system and my pool hold 8000 gallons i can run the chlorinator 24 hrs a day and it will not get the chlorine and free chlorine above 1 the ph is 7.5...
Yes, what is your stabilizer level? It should be between 30 and 50 ppm. If the stabilizer is too low then the sun will cause the chlorine to dissipate faster than the chlorinator can produce it. Some salt chlorinator manufactures recommend 80ppm but that reduces the chlorine efffect. If you can't get the chlorinator working then using a floating tablet chlorinator is a good option to keep the pool open. I hope this helps.
Aug 12, 2011 | Intex Automatic Salt Water System for ...
The intex system light is green ,but when i test water no free chlorine is registered
I have an 18 X 33 X 48" oval pool (14000) gallons and I run my pump in the summer months at 10 to 12 hrs and chlorinator at 8 to 10 hrs of those pump hrs and hit a chlorine level at 2.0 to 2.5 ppm.. Green chlorine light means you are generating, it does not mean you have the correct level.. Increase your cycle time and check after 3 days... Please post a comment if this helps! Good luck,,
Aug 08, 2011 | Intex Automatic Salt Water System for ...
The walls and bottom are getting slick what should we do to solve the problem?
This is an indication that your unit is not producing enough free chlorine...
Big pools require up to 12 pump hrs with 10 chlorinating hrs. (depending on outside temperatures) and electrolytic cell must be maintained clean. If your unit is clean and you have the correct salt level, try this;
Brush your pool with pool pump and get all that slick stuff off.
Clean you filter...
Set your pump to run 12 hrs with 10 hrs of chlorinator. You will see results in 2 to 3 days..
Clean your filter again..
After pool water clears and chlorine level raises, adjust time as needed..
Hope this will do it for you. If it helped, please rate!!
Jul 20, 2011 | Intex Automatic Salt Water System for ...
Recently installed Intex saltwater system, all of a sudden, have green forming around walls of pool. All levels look okay; except chlorine is a little low and PH is very high...I ran the boost cycle last...
Once you get the "Green" stuff on the walls, you must brush it off.. and one boost cycle will not do.... Make sure you have the correct salt level!!! Keep in mind..big pools can take up to 350 lbs of salt... Now...set you pump at 12 hrs and you chlorinator at 10 hrs between those 12 hrs.. Run this cycle and you should see results within 2 to 3 days... Clean you filter and rinse your electrolytic cell after 3 days because you will have dead algae. After the water turns clear, you can then lower your cycle to 10 pump and 8 chlorinate.. Good luck! hope this helps!
Jul 19, 2011 | Intex Automatic Salt Water System for ...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
No chlorine being produced
although you are close to the amount of salt that is recommended all pools are just different enough that the salt table is just a starting point if you do not have enough salt it is still possible to not trigger the alarm but not produce enough chlorine.
Start by getting a salt test strip kit and get your pool to 3000ppm this may take a day or so since you really need to filter and circulate the pool for 24 hours in between adding salt
Once you get the salt right then move on to generating
also do not worry about total chlorine you just need to concentrate on free chlorine this is the amount available in the pool to do it's job and dont forget to ad a stabilizer to help hold the chlorine level on hot sunny days
Jun 05, 2010 | Intex Automatic Salt Water System for ...
Saltwater System won't bring chlorine level down
depending on the type/brand of salt cell/system you have I would recommend turning it to its lowest setting or off. Most salt cells don't measure chlorine level and will keep producing even if its crazy high. Most cells produce chlorine at about 8.0pH, so it will keep raising your pH as it generates. I would leave it off for a couple of days, get control of your pH and keep measuring your free chlorine level until it's acceptable. If you need to lower your chlorine level quickly you can use sodium thiosulfate to do so. You will have to add acid frequently to compensate for the salt system. Keep an eye on the TA as adding alot of acid will eventually lower your TA as well. Hope this helps.
Sep 16, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
663 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
