Question about True TD-95-38-LT Beverage Cooler
With the thermostate off the interior fan runs but when i turn the thermostat on it trips the breaker
  • 4 Answers
Not good! The thermostat only supplies power to the compressor section, so a breaker tripping is a sign of a 'dead' short to that area. If lucky, it just an exposed wire or terminal connection damaged in that area, but rarely the cause. More likely is compressor mtr "locked rotor", or stuck "potential" start relay holding the mtr circuit in hi-amp load, or shorted internal motor winding's. The condensor fan can also short closed, but is rare due to it's design. I have to assume the electic breaker suppling that circuit is not failing, as cause?
Posted on Jul 11, 2010
Kenmore refrigerator (bottom freezer)
U MAY HAVE BLOWN THE COMPRESSOR RELAY DUE TO THE TRIP? U CAN REMOVE IT FROM THE COMPRESSOR AND SHAKE IT IF U DONT HAVE A METER TO TEST IT, IF IT RATTLES THEN ITS BAD? IF THERE IS A CLICKING WHEN COMPRESSOR IS TRYING TO RUN ITS BAD, OTHER WISE I WOULD SUSPECT A BAD COLD CONTROL THERMOSTAT ESPECIALLY IF UR TURNING IT FROM UNDERNEATH AND NOT JUST THE KNOB? DID U USE A SCREWDRIVER TO GET INTO THE TINY SLOT UNDER THE TIMER AND TURN IT SLOWLY TILL U HEAR A CLICK? TURN AGIN AND THE NEXT CLICK SHOULD TURN IT BACK ON U SHOULD HEAR THE COMPRESSOR AND THE FAN WORJKING
Mar 14, 2015 | Kenmore Refrigerators
Why does AC Duo-Therm thermost throw the breaker and needs set to approx 55/50 to run ?
`Try changing the breaker some times they get weak and will trip at start up. Also check for bare wire shorting out. Then check capacitor then fan motor spin blades to see if they spin easy and that bearings are not bad.. make sure all connections are tight with no corrosion. These problems show up more with short cycling then with long.
Jun 27, 2014 | Dometic Rooftop RV Air Conditioner
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
Thermostat sticking titan n180
The thermostat is there to protect the water heater. I don't think it can overheat and make the breaker trip. If you tried to reset the unit and it's still not working, you should send your Titan N180 back to the manufacturer to be repaired. The 10 year warranty if against leaks. You have 1 warranty in your Titan components.
Apr 01, 2012 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Honeywell MagicStat 3200 Fan continues to run--I flipped furnace breaker off for an hour, set stat to off, & flipped breaker back on. fan still runs. Fan control is on Auto.
Hello,If just installed the thermostat check that the wires are not touching anywhere.If not the case you have a open(tripped) HIGH LIMIT at the furnace and the blower will continue to run untill it is reset.
Oct 30, 2010 | Honeywell Programmable Thermostat Heater
Heat pump that runs with the thermostat in the off position
On heat pumps your fan is controlled by a relay on your control or defrost board. It is possible that that the relay is stuck or the points welded together or the control board could be bad.
They need to check all the incoming volts to the board, there may be volts coming from another source. If not and the fan still runs that would be something in the board is bad.
As far as tripping the breaker, it could be weak or something is drawing high amps. If the motor is running then it's probably the compressor, but I can't say for sure without checking it out. You also have a capacitor and relays that also could be bad or shorted.
Jun 10, 2010 | Heating & Cooling
A/c outside not working
The buzzing noise is your contactor drawing in from your thermostat. The fan part of your unit is on a different circuit from your outside A\C unit. Your thermostat is the conductor of the orchestra tying ths units together. It may well be that your A\C circuit breaker has tripped, if it has there is a reason for it's tripping. Resetting the breaker by turning it off then on may get your unit running, but a technician needs to ascertain why it tripped. Or it could be a bad contact switch inside the outside unit not letting enough electricity through the switch. More than likely the first issue. Good Luck
Jul 15, 2009 | Goodman CKL36AR36 Air Conditioner
Thermostat won't stay on, even with new batteries on hunter therm
replace the thermoste with a new one its easy to do
1.turn of breaker to doorbell air handler and compresser (outsideunit)
2 take of thermostat lble wires as to wich leters they conect to
3 put on new thermostat enshuring whires are conected to corect letter
4 turn on beakers and enjoy!!
Jan 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Jun 08, 2008 | Goodman CLQ36AR49 Air Conditioner
True TD-95-38-LT Beverage Cooler Logo
91 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
