Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
No chlorine registering; plates need cleaned every few days
We have the Intex Ultra Frame Pool with Saltwater System. We have put in the recommended amount of salt for the size, tested the salt which shows the ideal ppm, but we continue to have problems having an test strips register any chlorine. (We've tried 3 different brands). I have continued to up the amount of time we run the sanitizer (we are now at the max). We know we have high calcium in the water because we have to clean the titanium plates every few days. We change the filter very regularly (every 3-7 days). I'm reluctant to use any other products not knowing what you should or should not be using with the saltwater. Its becoming very frustrating.
  • 297 Answers
The recommended amount of salt is just a guide> You say yours is ideal
would that be 3000ppm and are you using test strips for salt that are 3 reading or color reading
Go with # reading they are most accurate any lower than 2800ppm and you will not generate enough chlorine and could trigger low salt code any higher than 3500 and it will taste bad and could trigger high salt alarm
when adjusting salt you need to filter only for 24 hours before trying to generate chlorine
I have never cleaned my electro cell
other chemicals should include a non foaming algaecide once a week follow direction for your gallons of water
Also chlorine stabilizer once a month or so depending on conditions this helps hold the chlorine level
and a water clarifier this helps the minute particals clump together thus being possible for the paper filter to catch it.
The paper cartriges let to much small debris through that you cant see
The key to using an intex system is filter filter filter if you do not filter enough you will next go green and that is a nightmare
Have 2 filters so that while one is being used the other has been blasted out with a garden hose and drying An inserted dry filter works better than a freshly cleaned wet one
I have had the same 2 filters for this being my 4th season
I run mine 24/7 it is like keeping a 40 watt bulb on
Posted on Jul 09, 2010
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
How do i fix my saltwater pool its green?
it sounds like your chems are off, check you chlorine and PH, I go for a 3.0 to 5.0 on the chlorine side and 7.2 to 7.5 on ph,
Jul 29, 2014 | Intex 2500 GPH Filter Pump Krystal Clear...
24' X 52" intex pool, I am having trouble with my cholinator not producing chlorine in the water. there are no signals or lights flashing. but when I test for the free chlorine on the strips is do
If you can remove your generator try and bench test it. Fill with pool water and do a chlorine test. Run the generator for a few minutes, unit should produce bubbles when the cells are turned on. Run another chlorine test and make sure it is higher than original test. You should also test your combined chlorines to make sure you don't have excess chloramines in the water. Also check for any buildup on the generator plates which should be acid washed, and verify salt concentration.
Apr 01, 2013 | Intex Automatic Salt Water System for ...
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
What is the recommended end-of-season maintenance for the chlorinating pump?
According to the Intex website, the following maintenance is required for this product:
The Intex Saltwater Pool Systems are designed to operate with a minimum amount of maintenance. It is recommended to always turn the pump on prior to turning on the Saltwater Pool System (see Owner's Manual) unless the chlorine generator is part of a combination pool and filter set, to ensure that air pockets are eliminated from the hoses, and that water is flowing through the unit. In addition, the electrolytic cell should be examined and cleaned if necessary. The frequency of cleaning will depend on the local water conditions, pool usage conditions, and length of time the Saltwater Pool System is operated each day. (See Owner's Manual.)
The Intex Saltwater Pool Systems contain several features that minimize maintenance requirements:
1.) An automatic self-cleaning cycle: The Saltwater Pool System automatically undergoes a self-cleaning cycle to maximize the operating length of the electrolytic cell.
2.) Safety diagnostics: the Saltwater Pool System will alert the operator to three conditions that could result in poor operation: Low water flow through the unit, Low Salt level in the pool water, High salt level in the pool water. If any of these conditions exist, the system will sound a buzzer, and flash a digital code on the control panel (Model 8110) or a Red LED will light up. (Model 6110).If the condition is not addressed, the system will automatically shut itself off to prevent damage to the unit.
Sep 11, 2011 | Intex Automatic Salt Water System for ...
I just put up an 18x52 Intex ultra frame pool last week, The saltwater pump and filter pump have both been ran daily for 12 hours.. No codes from the saltwater system, and the water is crystal clear.. ...
I sometimes have the same issue with mine.. One thing missing that helps protect the chlorine from burning off in the heavy sun is (Cyanuric Acid)or (CYA) You should be around 30-50ppm.. To bring this level up to 30-50, they sell a conditioner that raises this level.. Don't add too much if your already close to the 30-50ppm.. Other than that, you can continue to run the system as you already do.. Seems like it's maintaining clean and clear... Hope this helps???
Aug 31, 2011 | Intex Automatic Salt Water System for ...
Ok i have the intex 1600gph sand filter saltwater combo system and my pool hold 8000 gallons i can run the chlorinator 24 hrs a day and it will not get the chlorine and free chlorine above 1 the ph is 7.5...
Yes, what is your stabilizer level? It should be between 30 and 50 ppm. If the stabilizer is too low then the sun will cause the chlorine to dissipate faster than the chlorinator can produce it. Some salt chlorinator manufactures recommend 80ppm but that reduces the chlorine efffect. If you can't get the chlorinator working then using a floating tablet chlorinator is a good option to keep the pool open. I hope this helps.
Aug 12, 2011 | Intex Automatic Salt Water System for ...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
I have an Intex Krystal Clear Saltwater System, model CS8111. My problem is green water. I had been out of town for a few days and when I came home the pool was green. Also the low salt light was on. I...
If your salt is at the correct levels required for your pool and your still getting the "91" code on your LCD screen do not add more salt you need to clean the plates on the chlorinator. Look at your manual and it gives you instructions on how to remove, clean, and replace the chlorinator section on the pump. Reminder, if your PH and/or alkalinity levels are off you'll be cleaning the plates often because of the scale build up. I personally run my pump 4 hrs daily and I have never had a problem with green water however, once it did become cloudy (white) I began treating with algaecide and changing filter every 3 hrs. It cleared it right up. I love the Krystal Clear System.
Jun 26, 2011 | Intex Automatic Salt Water System for ...
No chlorine being produced
although you are close to the amount of salt that is recommended all pools are just different enough that the salt table is just a starting point if you do not have enough salt it is still possible to not trigger the alarm but not produce enough chlorine.
Start by getting a salt test strip kit and get your pool to 3000ppm this may take a day or so since you really need to filter and circulate the pool for 24 hours in between adding salt
Once you get the salt right then move on to generating
also do not worry about total chlorine you just need to concentrate on free chlorine this is the amount available in the pool to do it's job and dont forget to ad a stabilizer to help hold the chlorine level on hot sunny days
Jun 05, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
768 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
