Question about Baby Trend Reebok Velocity Stroller
How to use the mp3
The mp3 and the pedometer dont work all i see is zero zero and when i press the buttons nothing happens
I cannot get it to take a charge. I plug it in to USB port and nothing happens. Help
Linda, try a different usb port and a different cable, if this does not work may need new battery.
press the helpful button.
Jan 20, 2016 | Fitbit Flex Wireless Activity & Sleep...
When does the clearview pedometer reset
I'm responding 'cuz my Clearview pedometer remains something of a mystery to me, too. So I apologize, right off, about the length and confusion in this procedure. Maybe someone will add a simpler, comprehensive list of commands.
W/o access to a user manual, here is what I've learned about it. Barbara, I didn't think it reset itself... maybe you can explain. I did find that when I hit the "reset" button on the back (to the left of the belt clip), it resets the Step (number taken), Mile (distance traveled), and Kcal (calories burned) to zero. One click for all-three together.
More SETTING steps: The menu is a vertical column to the right of the digital display (from top to bottom: Step, inch, LB, Mile, Kcal). As you scan down the menu, look for the teeny > arrow pointing at one of the functions. Normally the arrow skips from Step, to Mile, to Kcal. If you've been using it, and there are numbers in these fields, you can manually reset these to zero by pressing the "reset" button. Those 3 fields should now register "0" when you scan through the modes as before. I believe this does not reset your stride or weight settings.
These other 2 modes: inch (length of YOUR step), and LB (YOUR weight = this helps in calculating your calorie consumption... I think) were a bit tricky to reset to MY body. I managed to select those modes and enter my own data somewhat haphazardly, by simultaneously pressing the two buttons on the right (Mode, and Set); and then (sometimes, but not necessarily?) pressing the Set button alone. Either way, if you're lucky (!) you'll eventually get a blinking number and the arrow > indicating which field you're in: inch, or LB.
If it is the inch field, it will read 0, or something like 30 (your stride in inches). If you want to change it, press the SET button repeatedly (lower/right) to INCREASE the number in the field. Apparently you can't lower the number directly - if you instinctively press the upper/right button (MODE), it just closes the setting function.
So in order to set to the length of YOUR step, keep pressing (or you can hold it down) until you reach your stride length... it continues up to 120 inches (!!) before restarting at zero. I haven't figured out why it opens in inch, or in LB, but by randomly pressing both rt-hand buttons, I can eventually get into each of the two fields. The weight settings in LB also adjust only upward by pressing the SET button (that is, once you get the field to open). You may have to go to 150# (its max. setting) before you can begin at zero again. Last weird note: When I can't seem to get into these fields at all, I have had some success by pressing and HOLDING the SET button until the reading (usually 0, by then) blinks off and then on, once. Then you can proceed with the other steps.
Mar 24, 2014 | Ariel Premium Supply Clearview Pedometer
My Tanita PD-724 keeps resetting to zero during the day and also resetting the clock at random times
The same thing has been happening for me. I don't have a tried and tested solution, but I'm suspecting that it's when I keep the pedometer in the same pocket as my mobile phone. I'll make sure I don't do that and report back if it still resets.
Feb 01, 2013 | Tanita 3 AXES PEDOMETER (PD724)
Beeping won't stop in Sportline 370 pedometer
Use MODE button to scroll to ALM (alarm) then press INFO button to change from ON to OFF. If that doesn't work use MODE button to scroll to PACE, then press INFO button to toggle from ON to OFF.
Feb 27, 2012 | Sportline 370 Traq Motion Sensor Pedometer...
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
I have the most simple sportline pedometer. I want to change it from Km to miles...can't figure it out and have lost the instructions.
Hit he Mode Button until you reach the Distance Mode (MIL or KM) will appear on the display. Press and hold the Reset Button (S) until the display changes to the mode you want. Note that performing this step will reset all your readings to zero and return your stride and weight setting to the factory settings.
Manual here: http://www.sportline.com/manuals/303.pdf
Jan 01, 2011 | Sportline Exercise & Fitness
I have just bought a Tesco OneBody pedometer and cannot fathom out how to reset it after each use. The instructions are worse than useless - it took me ages to set the time and I'm not normally considered...
The instructions are totally useless: however, I think I've worked it out.
1. Start by setting the time: press the mode button and cycle through until you reach the time display. Press and hold the Set button until the time flashes. Press the adjust button to add one hour. Press set again to get the minutes to flash. Press the adjust button to add a minute. When the correct time has been set press Set.
2. Press the mode button to cycle through to Steps count (this will be a single number, probably fairly low if you've never tried to use it before). Press and hold the set button until the display changes and flashes for KG and CM. Press the adjust button (ADJ) to add a KG until you reach your correct weight. Now press the set button and the CM will flash. This is the measurement of your standard step, not how tall you are. Measure your step (the one you will take when either jogging or walking depending on what you want to use the pedometer for). This measure is from your back foot toe- to your front foot heel. Now add this number into the CM column by pressing the ADJ button once to add a centimetre. Press set again when you have added the correct number.
3. Finally you need to reset the pedometer: go into KCAL mode and press and hold the ADJ button: this will reset the steps, KM and KCAL counts to zero: Hey presto you are ready to go.
Hope that helps :-)
Oct 02, 2009 | Omron Body Logic Body Fat Analyzer HBF...
I can't figure out how to turn it on.
I checked this forum this morning because I was having the same trouble. I tried pushing buttons, pushing and holding buttons, pushing buttons together, shaking it, shaking it while holding buttons... nothing worked. Out of frustration more than anything I whacked it on the palm of my hand... and presto! It works. I guess you just need to use the Fonzie method.
Jul 28, 2009 | VIA Pedometer - Via Panic
I am having problems with my Pedometer. What should I do?
Review the following questions for common pedometer troubleshooting: a) Where are you wearing the pedometer? Make sure you are wearing your pedometer correctly by following these steps: * Clip your pedometer to your waistband or belt, directly above your knee. * Be sure your pedometer is perpendicular to the ground, not angled or dangling from your clothing. * Do not wear the pedometer on your shoe, sock, pocket or wrist. It will not provide an accurate reading. * Test the pedometer for accuracy by setting the step counter to zero and walking 50 steps. Check the display. If the reading is between 45-55, your step counter is functioning properly. If it reads more or less, reposition the counter on your waist and check again. * Your pedometer may give inaccurate results if you have had recent surgery or knee, leg, or foot problems. You may be favoring a leg or foot while walking. b)My pedometer has a clicking or loose part sound? Is it broken? No, a clicking or loose part sound is not an indicator of a broken pedometer. Every pedometer has an arm or pendulum inside of it. This is what counts the steps. The clicking noise that can be heard when the pedometer is shaken (or when you are walking) is the pendulum. c)The reset button will not work. The pendulum inside the pedometer is linked to the step counting device. The pendulum may become immobile from time to time, and this can prevent the reset button on the step counter from doing its job. If pressing the reset button a few times does not clear the display, here is what you can do to release the pendulum: * Give the pedometer a few gentle shakes while keeping the reset button held down. This un-sticks the pendulum. * Release the button. If the display has not cleared, press and release the button one more time. * If the display does not reset after trying this once or twice, call Customer Service.
Dec 01, 2008 | Gaiam Walking Fit Kit Pedometer...
Frozen !!!
Press and hold the volume up + key and the select button to perform a "hard reset" Best of Luck.
Aug 22, 2007 | SanDisk Sansa c150 MP3 Player
Baby Gear Logo
41 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
