Question about Insignia Pilot MP3 Player
Profiling Media Files
Help! when i turn on my Insignia NS-4V24 machine, it will go past teh welcome screen to the screen that says "PROFILING MEDIA FILES" and it just stays on this screen no matter how long i keep it on!!! is there a reset button or something? or some way to fix it without losing my files?
  • scottishman3 Jul 01, 2008
    same problem, little background info, pilot worked fine for a while, until i put it on my friends mac just to charge. after that it the pilot would not read certain songs (some error that it couldnt open up the file) and wouldnt let me delete the songs on the pilot, so i connected with the usb to delete the songs off the pilot from my laptop. tried to put the same songs back onto the pilot with windows media player sync. it wouldnt sync and immediately after when i tried to turn on the pilot it froze on the "profiling media files" thing without ever making it to the menu. held down the power 10 secs so it would turn off, then turned it back on...same problem. eventually ran out of battery, thought that would be good, but not cant even get enough battery from the usb charger to try the trick with the menu button
To reset the Pilot completely, turn it off, then press and hold the "Menu" button in the corner. Keep holding it as you power on the device and eventually it will ask you if you want to reformat internal memory. Say yes and your done. This will erase everything you have on the player, but at least it will work again.
Posted on May 27, 2008
Saw this on a different forum, didnt work for me, but you can try
"My 4 GB Pilot has been stuck at "Profiling Media Files" for several hours. I tried the soft reset by pushing down the power button for 20 seconds. I disconnected the battery and I set it to Hold and then tried connecting to my PC - all to no availal. The thing is stuck. And I live 3 hours from the next Best Buy store.....is there a way to flash the firmware (if I had it) to unstick the Pilot? I'd be happy to reformat the player if I just could get into the menu....
Any suggestions anybody, pleaseeeeeeee...
Barb
Fixed it...left it running and stuck on the same screen all afternoon, then - in a moment of rage - I turned if off and back on again while pressing all kinds of keys and switches and buttons and all of a sudden, a dialog popped up asking me if I wanted to format the internal drive. I did and the player is back and functioning normal!"
Posted on Jul 02, 2008
My players screen says profiling media files... i can not load any music
I had this happen to me a couple times, I removed the back and disconnected the battery for a few minutes, then when I reconnected the battery it worked fine.
Nov 25, 2009 | Insignia Pilot MP3 Player
What format should I name my files?
I have found that videos need to be in MPEG 4 and photos JPEG
Sep 27, 2009 | Insignia Pilot MP3 Player
My mp3 freezes when turning on
take out the battery and put it back it worked for me.
Sep 05, 2008 | Insignia Pilot MP3 Player
Need manual for Insignia NS-4V24 MP3 player
pull switch on right top to the right until it comes on. same to shut off.
Jun 11, 2008 | Audio Players & Recorders
NS-4V24
Hi i just wonder if there is a way to load your personal background/wallpaper
into the NS-4v24 Pilot Player
Jun 01, 2008 | Insignia Pilot MP3 Player
Frozen NS-8V24
I pulled the battrery cover off and removed the battery. Leaved out for a couple of minutes then replaced and reversed the order. Then I turned it back on, and it still stays at the "Profiling media files" box. What should I do?
May 10, 2008 | Insignia Pilot MP3 Player
Insignia Pilot 4GB MP3/Video (NS-4V24) No Longer Works
ok on the pilot i figurtred out there is a small screw being covered by a lil black piece. it looks to be a small plastic poece but it's just a lil cover stuck on. peal it off and unscrew it don't break it off to find out how to get to the battery(\like i did).
Mar 30, 2008 | Audio Players & Recorders
Insignia NS-4V24 sync error
Most likely a issue in the FAT or similar table. The tables used on the internal memory is allocated only for short files names since most media managers change the file names to fit 8.3 dos. They do this since mp3 and mwa audio files use id tagging. So try renaming your mp3's that its eight letters or numbers then the three letter extension .mp3 = rap0001.mp3
Mar 22, 2008 | Audio Players & Recorders
I lost my software cd for insignia NS-DV2G........so, now i can't download any songs!.....what should i do?
You can use Windows Explorer to transfer files to your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your mp3 files from your c drive to the new drive for your player. You'll notice that when you delete the files on your new drive for your player that it doesnt remove them from your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. Dave@OgleServices.com
Feb 17, 2008 | Insignia NS-DV2G MP3 Player
Insignia Pilot MP3 Player Logo
412 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
