Question about Sharp AL-1641CS Laser Digital Copier
MY AL-1641CS LEAVES A THICK LINE ON THE PAPER. I
MY AL-1641CS LEAVES A THICK LINE ON THE PAPER. I LOOKED AT THE DRUM AND IT HAS BLACK MARKS ON IT. I RUBBED IT OFF, BUT AS I TURN IT, IT KEEPS GETTING BLACK AGAIN. WHAT SHOULD I DO?
  • 1,110 Answers
If the drum is rotated in the proper direction, it should be clean. If the line on your copy is in about the same location from to back as the line on the drum then your only option is going to be to replace the drum unit. The drum unit contains a drum cleaning blade that is supposed to clean the drum as it is being rotated. This is apparently not working in your case. These cleaner blades can be replaced if you have someone locally that can do it. The cost of a cleaner blade is about $20.
Good Luck and Thank You for using Fixya.
Posted on Jul 09, 2010
New toner and new drum and paper come complete dark
Hi there, it seems that the paper was coming out black not because of drum or toner .Replace the drum cleaner blade and developer as well. If it comes black again, check the charge unit and replace it then clean the optical parts that is the document glass and the small mirrors.
Jan 20, 2011 | Sharp AL-1641CS Laser Digital Copier
Tip
Sharp AL-1641CS Copier Manual Download
Free Sharp AL-1641CS Copier Manual Download
Models: Sharp AL-1632 / Sharp AL-1641CS
Would you like to review the features of the Sharp AL-1641CS Copier?
Have you lost your Sharp AL-1641CS Copier Owner's Guide?
Would you like a free digital, searchable, pdf version of the Sharp AL-1641CS Copier Manual?
Follow this link
(& click FREE) to download a pdf version of the Sharp AL-1641CS Copier documentation.
I hope that helps.
___________________________________________________
on Jul 24, 2010 | Sharp AL-1641CS Laser Digital Copier
My copies come out very dark, I replace tone and drum and still have the same problem. Please, help
go to ara that has serveral setting for print set. or change the font it might be on a thick dark setting.
May 13, 2009 | Sharp AL-1641CS Laser Digital Copier
Reset the copier counter AL-1641CS
Which reset are you trying to preform
the counter for the drum unit ?
Apr 01, 2009 | Sharp AL-1641CS Copier
BLACK MARKS ON PAGE
if the black marks are in teh same place every time and you are putting teh page on the exsposure glass give the galss a clean as there could be some ink or dirt on it .. if the marks are moving across the page it could be down to the drum being marked or if he marks are spaced a bit wider it could be the fuser has a mark on it check these as well.. if the mark is a line look at where the paper goes through the document feeder check the thin **** glass it passes over to make sure there isnt any tipex or ink left on it.. all the glass can be cleaned with regular glass cleaner and a soft cloth
Mar 25, 2009 | Sharp AL 800 Copier
Makes copies but leaves a streak of toner on the sides ofthe copy
Drum unit is most likely the problem, but you can confirm that, by removing it, and seeing if it has toner streaks on it, after making some copies. If so -replace.
*Please Rate me ;)
Mar 24, 2009 | Sharp AL-1641CS Laser Digital Copier
2 lines down the right side of paper - sharp 1641 CS copier
Your problem is most likely not the drum.
Can you make a copy on the glass itself and the lines DO not appear?
if yes this confirms it is not from the drum. Open the top and look at the Small strip of glass : is it dirty or have two dots, white out or Anything on there???? clean w/ alcohol. Any dots will look like lines when making a copy because the paper is moving on the glass.
If the lines are still coming out even on the glass then take a look at the Fuser (exit where it gets hot) are the rollers smooth and uniform or are they scratched???
Dec 11, 2008 | Sharp AL-1641CS Laser Digital Copier
Double left line down the side of paper
Sounds like the drum surface has been damaged by some foreign object.
Typically when you get imaging errors such as lines from top to bottom of a page there is a permanent scratch on the drum surface. Pull the drum unit out of the printer/copier and carefully examine the drum surface, you most likely will see the damage quite easily. The only repair is to replace the drum unit with a new one. HOWEVER... be sure to clean the inside of the machine with a toner vacuum to remove any dirt, debris or paperclips, staples, etc that might have accidentally been introduced into the unit.
Hope this helps you out.
Cheers,
Keith
Dec 04, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AL-1641CS printer/copier
Most likely you had a toner cartridge failuer leaving some of the ink and developer in the crevices above the paper feeder and its just trickling onto the paper.
It pretty much needs to have the cartrides taken out and thouroghly vaccumed.
Just takes patience and time to get it all removed.
Dont vacuum the cartridges, but the inside of the machine.
Pull your paper tray out and see if there is toner and developer trickling into it.
Jan 09, 2008 | Sharp AL-1641CS All-In-One Laser Printer
Sharp AL-1641CS Laser Digital Copier Logo
77 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
