Question about HP PhotoSmart C4480 All-in-One Printer InkJet
My HP Photosmart 2610xi all-in-one printer,fax,scanner,copier said ERROR Remove and check cartridgeon right.
  • luciariovist Jul 09, 2010
    My HPPhotosmart 2610xi all-in-one printer,fax,scanner-copier is not working the light of Cancel is blinking and the on light dosen't go away! or I can't turned off!!!
    President:
  • 3,278 Answers
Hello.
The solution could be as simple as changing your cartridge. But, check the expiration date. HP hard-codes in an expiration date on the cartridges. Use the cartridge before the expiration date.
Hope this helps.
Posted on Jul 09, 2010
  • NinaE Jul 09, 2010
    For the light: if the printer doesn't power off, disconnect the printer from its power source (power strip, outlet), wait 30 seconds and reconnect.
  • 857 Answers
That silver wire -- is it attached to a sensor that causes the error message, or is the message specifically a result of the printhead contacts not matching up to the contacts on the cartridge.
You may use epoxy.
You need to check if the wire has ripped the printhead contacts.
If it has then your machine is not repairable.
Contact Hp support if it is in warrenty.
Suddenly stopped scanning and gave error message that scanner not connected. This is not true. Went on HP website. Useless. Says there is no scanner attached to computer. Yes there is. I have used it for...
The scanner has a separate driver as does the printer portion. They are installed separately. Download the scanner driver or re-install the disc that came with your printer.
Nov 26, 2010 | HP Photosmart 2610xi All-In-One InkJet...
Not receiving fax - notes is error 410* prompts the following: "a communication error occurred during the fax transmission. If your sending try again....
Hi! I will be glad to assist you in this issue. here is the link to fix the issue.
Interpreting Error Codes in Fax Communication Error or Fax History Reports:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=421139#Error396
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02151&cc=us&lc=en&dlc=en&product=421139
Nov 08, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Error Message on screen
Check two things
1. Ink in your catridge
2. Check whether the catridge has been proprely inserted because some movement to the printer may cause the catridge postion to be misplaced
Hope your problem got solved
Please rate my solution
Thank you
Oct 22, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Hp photosmart 2610xi does not scan.
Remove all hp software and drivers from control panel>add remove programs. Then go to control panel>system and go to hardware and then device manager, then delete your printer/scanner from the list by right clicking and 'uninstall'. Then restart, and make sure you printer/scanner is unplugged and off. Then once your computer restarts go to hp's website and make sure you selected the right country (at the top), then go to support & drivers and download the software/drivers that are for your printer/scanner. Once drivers/software is install, then connect printer (or follow installation instructions, if different)
Also, just to make sure, plug it in a different USB port (after the reinstallation) incase the old drivers are stuck on the computer somewhere. Drivers usually/sometimes are associated with a specific usb port and will reinstall when plugged in a different port.
Mar 07, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Jun 10, 2008 | HP Photosmart 2610xi All-In-One InkJet...
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
49 people viewed this question
Seeker5211
Seeker5211
