Question about General Electric WCSR2090D Top Load Washer
General Electric WCSR2090D Top Load Washer accidently overfilled, now when we start a cycle it starts aggitating immediately. When I shake the loading bucket I can hear water splashing
  • 1,543 Answers
You will always hear that water, as it is a liquid in the balance ring around the top of the drum.
Take the front off by using a putty knife to push in the two clips at the seam where the front meets the top while pulling on the top of the front panel. Now, with the washer empty, take the small hose off the left side of the tub and clean out the gunk that is in the last few inches of the tube. Also, poke a thin wire into the nipple the tube came off of on the tub. Replace tube and front panel. Done.
Posted on Jul 09, 2010
My washer will wash clothes but does not stop at the end of the cycle it continues on into the white cycle and never drains
I think one of the contact points has come off on the timer, this would cause the problem you describe (there are many sets and several of them interact with each
other to produce desired cycles) They become burnt then detach occasionally.
Or, if this is a used unit, the timer may be incorrectly
installed (upside down). I have seen this a couple of times. Hope this is helpful.
Jun 13, 2011 | General Electric WCSR2090D Top Load Washer
Is there anything to do for maintenance of washer, any sort of cleaning or else
It is worth checking the filter every now and again to make sure that is ok.
It should be down at base of machine behind small flip cover.
Feb 06, 2011 | General Electric WCSR2090D Top Load Washer
My GE WCSR2090D top load washer has flooded our house in the past, and when looked at by a repair man he said nothing seemed wrong... so we continued to use it and it now leaks/floods only once in every...
You might have a partially clogged drain past your drain hose
(In the wall etc)
Thats overflowing behind the washer.
Watch the drain for a few washings and see if it overflows
It may be second or third or fifth load. Its hard to catch
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 08, 2010 | General Electric WCSR2090D Top Load Washer
The washer has water in it and the spin cycle wont function
the drain is clogged,take clothes out.And scoop water out.now put Draino-max and let i set in for 1-2hrs. then run empty through cycles.it may take 2x to drain propper
Jun 30, 2010 | General Electric WCSR2090D Top Load Washer
There is water left under the tub after the wash is over. When I move the tub I can hear the water sloshing. How can I get rid of the water. It makes my towels smell like mildew.
If it is draining down and spinning the clothes dry then all of the water is draining out. There is only about a 1/2 in space under the tub. There is a balance ring around the top of the tube that holds water. That may be the sound you are hearing? Try washing a load without anything in it on hot and use a box of baking soda. See if that will help with the smell. My washer leaves a mildew smell sometimes. I started running an extra rinse cycle on it. And that helped. I think it was my water.
May 28, 2010 | General Electric WCSR2090D Top Load Washer
My washing machine will not agitate but will spin. All it does is hum during wash cycle
the transmission needs repair, thats why the humming, the motor is turning but the gears are not engaging
Nov 28, 2009 | General Electric WCSR2090D Top Load Washer
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Won't drain need diagram for washer
If you need to know the diagram is found in control panel .Check for voltage to pump also make sure a sock is not stuck in pump .
May 18, 2009 | General Electric WCSR2090D Top Load Washer
General Electric WCSR2090D Top Load Washer Logo
173 people viewed this question
Top General Electric Washing Machines Experts
Sal De
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
