Question about Toro Lawn Mower With Toro Power Tools
Lawnmower front wheels are locked
Suddenly both front wheels of selfpropelled lawnmower are locked and will not turn
Take it apart and clean it. Grass and oil can easily clog any lawn equipment. Is it belt driven? If so turn the belt with your hand the way it would normally rotate. Follow the belt to the engine and clean the rotor if that doesnt work.
Posted on Jul 10, 2010
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
Lawn mower ran out of oil and stopped running put new oil in and still not running is there something to do after putting oil in to make it run
If you can turn blade by hand first removing spark plug you then can try squirting 30w oil into plug hole and turn blade by hand. replace plug and try to start. Depending on whether you gouged the cylinder it may start.
Jul 06, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Does 2stroke go in gas
If you are referrig to 2 stroke oil, the answer would be no. Generally speaking 2 stroke oil is mixed with gasoline at the appropriate ratio and is used in gas powered weed eaters and chain saws. A lawnmower for the most part is considered a 4 stroke motor. You only need to use gasoline in the tank. Make sure that at the end of the season the gas tank is pretty low or even allow it to run dry. This is simply to avoid the harmful deposits that old fuel can cause to gaskets. If emptying of the gas tank is not easy, you can add fuel stabilizer to ensure that the fuel is usable for the next season.
Jun 30, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Hit a stump with lawnmower, now wont start
You may have sheared the flywheel key. This throws the timing off. If the shaft isn't bent replace the key.
Jun 22, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Poulan pro 625 lawn mower idles slow and rough
Try changing your plug and check gap and put in some fresh fuel. Empty out the old stuff especially if it has been there a while. Also check your low idle setting on the carb open it up a half turn for starters. Good Luck...
Aug 27, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Self propelled lawnmower seems to be out of alignment
depending on the model the wheels sometimes have a ring gear assembly inside each wheel the parts/diagram for your mower can be found at: searspartsdirect.com
Aug 21, 2009 | Garden
I need replacement wheels for selfpropelled (front)power pro
You can go to searspartsdirect.com and enter your model number. Your mower is made by the same factory that makes the Craftsman mower so they should have it listed and you can order the wheels from them.
Jun 14, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Toro Lawn Mower With Toro Power Tools Logo
708 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
