Question about Sony KP-65WV600 65" Rear Projection HDTV-Ready Television
My sony kp-65wv600 has double immage and bleeds too much green what can i do
  • Sony Master
  • 8,457 Answers
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board must have it 2 convergence ICS and some or all it resistors to replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Posted on Jul 09, 2010
How I change the video input on my kp-65wv600
There are a couple of ways to cycle through the inputs on the KP-65WV600. The front panel TV/Video button will cycle through the inputs. (This is near the bottom of the button cluster between the Volume - and Flash Focus buttons.) On the original remote, you use also use the TV/Video button; it's above the 1 in the number pad section of the remote. For a third party remote, you will need to find the code that will enable a Source or Input button to cycle through the inputs on the TV.
These are shown in the manual which is available from the product support page: https://esupport.sony.com/US/p/model-home.pl?mdl=KP65WV600&template_id=1®ion_id=1&tab=manuals#/manualsTab . (This is the Manuals, Specs, Warranty tab.) The direct link to the manual is currently https://docs.sony.com/release//KP65WV600.PDF . See page 14 (page 15 of the PDF) for the front panel buttons; see page 48 (49 of the PDF) for the remote control buttons.
I hope this helps.
Sep 23, 2016 | Sony KP-65WV600 65" Rear Projection...
Seeing a double picture
See attached photos, do they look anything like your problem?
IF so I can tell you what is wrong and what is needed to repair it.
SD TECH
Oct 04, 2010 | Sony KP-65WV600 65" Rear Projection...
Looks like a double picture with red/blue/green line. I here there is a conversion chip you can buy. I already tried the convergence guide in the mauel. How do I fix ?
The set will need to have both of the STK-392-560 convergence chips.
I have photos of what the board looks like and the chips.
A pair can be purchased on EBAY for under 14 dollars.
This can be a do it yourself repair and I am able to tell you what is needed and how to do it.
Let me know if I can help with a very helpful rating on this solution and I will assist you.
SD TECH
Sep 13, 2010 | Sony KP-65WV600 65" Rear Projection...
My 65" sony rear projector
shorted green tube sony had major problem with Tubes
May 27, 2010 | Sony KP-65WV600 65" Rear Projection...
TV FADES TO BLUE AND THEN PICTURE DISSAPPEARS- AND SOMETIMES TV SHUTS OFF AFTER GOING BLACK WITH CONCENTRIC GREEN LINES
Turn your screen drive down to green and blue tube.
You have a focus/screen drive control block that you can adjust each tube R/G/B
Mar 17, 2010 | Sony KP-65WV600 65" Rear Projection...
My Sony KP-65WV600 65 in. Rear Projection Tv after turning on for a while the picture will turn cloudy blue. How do i fix this problem?
It is not unusual for the CRTs to cause this problem. In this case the Blue CRT. The problem is that you cannot get them anymore. You must send the CRT assembly to Sony for them to rebuild it. Due to the age of the set and the cost of this process, I do not recommend repairing if it is the Blue CRT causing the problem. The only way to be sure is to have a professional check it out.
I hope this helps,
Sky Assoc
Aug 25, 2009 | Sony KP-65WV600 65" Rear Projection...
Sony KP-65WV600 Convergence AD Board
It should be a 4.7 OHM if its under the heatsink near the convergence chips.
You can do the repair yourself using the following instructions.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 22, 2009 | Sony KP-65WV600 65" Rear Projection...
Cathode ray tubes (crt) for a Sony Rear Projection TV Model# KP-65WV600.
We have a problem with the blue as well. Sometimes it is good, then it fades to green. Then it went out and back on again. Repair man said it is a bad HT Block and would cost $350 to remedy.
Mar 13, 2008 | Vizio GV42L 42 in. LCD Television
SONY GREEN CONV OUT BLUE/GREEN OK,SONY KP-65WV600
Red,blue and green each have an amplifier IC--Stk392-560 x 2
Replace both IC's for reliable repair.Also,check  fuses,location sometimes ps5003-5008. fuse value 3.15 amp. ......T.
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-65WV600 65" Rear Projection HDTV-Ready Television Logo
139 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
