Question about Goldstar KG6000R Window Air Conditioner
Needs freeon fix self or take somewhere
Was working fine now wont cool the room think it needs freeon. is there a place to put it in ourselves or do i have to take it somewhere
  • 1,543 Answers
Adding refrigerant is not a do it yourself job. Most likely, you just have a plugged air filter. Generally, you will find a washable nylon mess filter just behind the front grill.
Posted on Jul 09, 2010
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Ac works but not cooling. The thermostat dosen't work properly.
open unit an check the thermoprotector on the compressor thats the problem
May 16, 2010 | Friedrich CP12C10 Wall/Window Air...
Air conditoner model gwhd5000 goldstar does not cool
Hi, first you will need to know, what type refrigerant,(freon) your a/c used, if you need to add freon, there's a leak in your a/c. you will have to find and repair leak, before you can charge/ add refrigerant(freon) . automobile a/c can be easily recharge (add) to system, but your window a/c unit, has the same principles but different approach, if you don't have experience, you will have to call mechanic, make sure you have a freon leak, before calling mechanic, plug a/c on let it work, put hands close to a/c, feel or check temperature of air blowing out from a/c, make sure compressor is working/running, fans could be working/ but compressor not, also put a/c thermostat to max, your model no. GWHD5000. means your unit is 5000 b.t.u, (british thermal unit) measurement of heat transfer, am wondering if a/c is to small for your space/room. making you think it needs freon, 5000. b.t.u. is for a small space,like a room 10' by 10' like a storage area or small bedroom, keep bedroom door/windows shut. measure you room/space/area , the bigger space/area needed to be cooled, has a chart, maybe you can find it on internet, any way a 10.000 or 12.000 b.t.u a/c is better buy, for normal room/space etc. so check compressor especially to make sure working, a/c could be to small for space/room, check it at night to see if it's colder. don't try to put gas/ freon yourself, could be very dangerous. but before calling mechanic, check those thing, mention before, could be your a/c are to small, for space/room etc. remember before attempting any repairs, disconnect power. good luck.
Aug 20, 2009 | LG Goldstar GWHD5000 wall/window Air...
How long will my AC work for, if placed inside the room
I assume that we are talking about a "window" unit. No, you cannot just place it in the room. The machine is actually two parts; one part delivers the cool air to you, the other part ejects the heat out of your house. If you just had the whole unit inside, the room wuold actually get warmer, not cooler. The reason for this is that the compressor and motor generate heat also. The "heat of compression" generated has to be ejected from the room in order for the air conditioner to work. Put it in the window.
Best regards, --W/D--
Aug 10, 2009 | Heating & Cooling
04 trailblazer, NO AIR coming through vents.
once a year you want to check the antifreeze/ freeon in your cooling system. from my understanding the cooling and heating system require this to function properly. they sell cans of this stuff at walmart that you can put in yourself.
Dec 21, 2008 | 2004 Chevrolet TrailBlazer
Air Conditioner
To answer your question , yes that what needs to be done. Sounds like the vents aren't blocked, just that the control motors aren't opening them.  It may be a bad switch, lose wire.  So to get it working as you were told you would need that fixed.  he price sounds a little high if all he is doing is charging it, without checking for leaks.
Sep 03, 2008 | 1999 Buick LeSabre
I have a self propelled Royal Dirt Devil vacuum model number 087900 and it goes backward fine but forward has to be pushed so hard it's impossible. Is this a switch? Do you know about how much the part...
You might try a new belt and/or brush roll. The brush roll is what helps pull a vacuum forward, the power drive helps, but if the brush isn't turning like it should, then it will hinder forward motion. The belt may look ok, but they stretch to the point that under load they won't drive the brush roll.
Feb 28, 2008 | Vacuums
Fridge cycling cool to warm
yes, you should not have a gap. It is allowing warm air to circulate in ref.
Jan 17, 2008 | GE GSS20IEM Side by Side Refrigerator
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Goldstar KG6000R Window Air Conditioner Logo
219 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
