Question about Sony STR-DE615 Receiver
I have a str-de615 Sony AM/FM Receiver and the "protector" flashes on after turning it on. The fuse was replaced and after turning it on it had a small smell of burning plastic. I have used a continuity checker and tested all the IC's after spending some time taking it apart. I cannot find one that is blown. The new fuse had a smaller amp rating and did not blow. It turns on fine. I like the receiver and do not wish to part with it. Could it be a particular IC ( Audio) The receiver was plugged into a power strip so I moved it to a direct electrical receptical. Still the same problem with a flashing "protector". Can I reprogram the receiver? Does anyone have the default code? Thank you, Kevin
    Top Expert:
  • Sony Master
  • 24,808 Answers
Protect mode is usually a fault with the output stages.
Posted on Mar 22, 2017
3 Suggested Answers
SOURCE: protector mode SONY STR D1011S am fm receiver
I've had this happen, it's when you have speaker wires crossed.....
Posted on Sep 22, 2008
  • 17130 Answers
SOURCE: str-685 has poor fm reception. have tried 3 different antennas.
If you are sure with the antennae then the fault is with the RF section within, It can be related to a faulty RF section, tuner or IF. You need to take a signal test to confirm.
Posted on Nov 01, 2011
Sony receiver stR se-501 found fuse burned after replaced turned on the flashing massage PROTECT come on . Did I miss anything?
Protect typically means that the fuse blew because something in your receiver went bad. It's now protecting your speakers from that badness. You need to get the receiver fixed or replaced.
Jun 16, 2015 | Sony Str-Se501 Stereo Receivers
How do I connect audio from HDTV to Sony STR-DE615 Home theater receiver as it has outdated connections
You maybe able to get adapter/converters to suit, if not get a savy friend to make up cables to suit your TV/Sony.
Dec 13, 2012 | Sony STR-DE615 Receiver
How do i get my sony DA30ES am -fm reciever out of protector mode
Here is a guide for you: STR DA30ES Protect
let us know how , if you need further assistance.
Jun 09, 2012 | Sony STR-DA30ES Receiver
My sony str- is getting a sony protector check code 22. Is that a fuse problem or do i have to get sony to fix it?
Unfortunately this is not a fuse problem, as the fuse would burn before the protector check code appears. Probably there is a short circuit and you should take to an authorized sony repair shop. Good Luck.
Jul 22, 2010 | Sony STR-DA5000ES Receiver
Sony STR-DE915 Receover, flashing "Protector" when power on
Serious problem either in the power supply or output stages of receiver.
Sep 16, 2017 | Sony STR-DE915
Stuck protector mode
find out why the fuse blew in the first place.the protector is just PROTECTING the main circuits of the receiver.the receiver turns on just to confirm the power circuit is OK.
have it checked by an electronic engineer.
Apr 16, 2008 | Sony STR-DE597 Receiver
SONY Receiver STR-DG510 does not turn on anymore.
Try, the fusível, if not work, try off the outlet 2 minutes, and plug in wall again.
-Verify the Voltage Selector too.
If after does not work, you need a techinical assistence.
Mar 09, 2008 | Sony STR-DG510 Receiver
Do you need a remote to fully power it on?
The problem was caused by a blown fuse. The secondary power supply was still functioning which powered the small LEDs and some of the switches on the front. The fuse went because a pair of the darlington driver transistors went (center channel I think) and some components on the rear speaker driver board.
Feb 16, 2008 | Sony STR-DE615 Receiver
Protector mode SONY STR D1011S am fm receiver
Dec 27, 2007 | Sony STR-DE945 Receiver
110 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
