Question about Kenmore 34720 Upright Vacuum
Smoke coming out of and funny roaring noise
Wondering if i can get it fixed or better to just buy new one
Theres smoke coming from the motor of the eureka pet pal bagless vacuum cleaner.. i dont know what to do
Some vacs have two belts. Is urs also self powered? If so, has a separate belt. With model # can give better info.
Nov 26, 2014 | Eureka Pet Pal Bagless Vacuum
My vax has just made a funny noise and now appears to be running on half power
If it's under warranty, take it back to your place of purchase as it sounds like the motor has blown. Otherwise you will need to buy a new one.
Sep 28, 2014 | Vacuums
I think the motor has blown. When turned on the vacuum makes a very loud, low roaring sound and it smokes terribly.
Yep, you are correct! Unfortunately, it's probably time to get a new one. I wish I had better news for ya.
Good Luck!
Jim
Aug 06, 2011 | Philips Vacuums
It was making a funny noise, then a burning smell, and smoke coming from under the cylinder which collects the dirt, then switched itself off. I have checked for blockages and can't see any
your motor is burned up. stop using the vacuum immediately due to possibility of fire. this is usually caused by the inner seal on the bottom of the cyclone lifts up or gets pinched and doesnt seal with the bottom lid.
Jan 03, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Vacuumm kirby hertiage made a funny noise and started to smoke and doesn't work.
Remove the cover and change the belt it may have got a rock stuck in the beater bar(brush)
Sep 12, 2009 | Kirby Heritage II Vacuum
My machine ran over some string,made a funny noise and emitted some smoke,the hand suction pipe at the rear works perfectly, the motor runs fine,but the front of the vacuum will not work.thankyou very...
the string bound up the beater bar (brush), keeps the belt stationary, and the motor spindle is just rubbing against the belt and melting it. remove the belt guard, remove the brush, and the belt. clean off the brush bearings (at the ends of the brush) of the string and make sure the ends spin freely from the brush. replace the belt with a new one, and put it all back together.
Aug 17, 2009 | Panasonic Vacuums
Dyson DC07 is very loud, roaring from the motor
It usually gets louder as the filters clog up and eventually burns out. Try replacing all the filters and giving the bin and the vortex generator a good blow out with compressed air. Fluff can stay inside and cause the motor to strain hence the increased noise.
It must still be under warranty -used to be 3 but now 5 years -so if it doesn't improve contact Dyson and they will repair it free of charge.
Mar 17, 2009 | Dyson DC07 All Floors Bagless Upright...
Smoke coming out of my Kenmore Canister Vacuum Model 22550300C
Sounds like a motor err. Could be repaired by a professional but it never be as good as a new one. Also they you might not find anyone to repair it because the replacement motor might cost more than a new vacuum /considering it's age the motor will be hard to find and that makes it more expensive to repair./
I suggest you to buy a new vacuum.
Feb 16, 2009 | Kenmore Vacuums
Hi folks, my beam vacuum makes a very loud roaring noise quite often. the problem started when i was vacuuming up a quantity of vermiculite from my chimney. i think i overloaded the vacuum i think and...
If the filter bag is bad and didn't trap all of the dust, then it got into your motor, so you may have a problem with your motor now.
Apr 20, 2008 | Vacuums
No suction
Bissell has made this model along with all of the older cleaners obsolete along with the parts for them. I would buy new.
Sep 05, 2007 | Bissell 1960-3 QuickSteamer Plus Upright...
Kenmore 34720 Upright Vacuum Logo
15 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
