Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
The engine cranks fine, but it will not turn over
Can't tell why the engine won't start-air cleaner is clean, fuel filter seems OK, battery is fine, so why does the engine crank, but just will not turn over? What can I check for? Could the spark plug need to be replaced? Thanks
  • 2,926 Answers
Pull the spark plug and test it for spark or replace the plug and see if it will start. You need three things to occur for any engine to run; Spark,Fuel and air. It seems the air factor is ok, not sure of the fuel factor based on the info provided and spark needs to be verified.
Posted on Jul 09, 2010
My d100 will not start
Check for good , strong spark. Take spark plug out and ground the outer core of the plug to the engine. Hold the plug with a pair of insulated pliers. Have someone crank the engine while you observe for a good strong blue spark. If the spark looks nice and bluish, then next would be to clean the carburetor. I suggest trying a "quick clean before taking the carburetor bowl off. Take spray carburetor cleaner and spray inside the carb throat with the air cleaner off. Also take about 1/2 can/bottle of fuel line injection cleaner and put it in the gas tank. Then try starting the mower. May sure the gas in the tank is fresh.
Jun 20, 2014 | John Deere Garden
Hard start condition after maintenence
Check Your Fuses: Few cars have a fuse associated with the starting system, but before you go monkeying around with everything, check your fuses to be sure it's not that simple.
Battery Corrosion: Over time your battery connections can become dirty, or corroded. This corrosion breaks the connection your battery has with the rest of the car, and it won't start. Try cleaning your battery posts and try to start the car again.
Dead Battery: The most common reason your car won't start is a dead battery. If you have a battery tester that can measure cranking amps, test your battery to see if it's weak. If you can't test it yourself, you can test the battery indirectly by jump-starting the car. If it starts right away, your problem is most likely a dead battery. Replace the battery, and clean the battery connections to ensure good contact.
Bad Igntion Switch: If your battery checks out, but the starter is still silent, it may be a faulty ignition switch. Turn the key to the on position (not all the way to start). If the red warning lights on your dash don't light up (and your battery connections are clean), the ignition switch is bad. If they do light up, turn the key to the start position. The dash warning lights should turn off at this key position (most cars). If you're not sure, turn on the headlights. When you try to start the car, the lights should either dim (a lot) or turn off completely. If they do, your ignition switch should be ok. If not, the switch will need replacement.
Bad Starter Connection:
Corrosion can not only keep your battery from connecting, it can affect any electrical component, especially the ones exposed to the elements like the starter. If you have a helper, you can test the connection by holding a circuit tester lead on the wire that engages the starter. This is the smaller of the two wires connected to the starter.
Aug 13, 2008 | 2000 Subaru Legacy
Bad cam shaft senser
You could have a faulty engine coolant sensor or intake air temperature sensor. Fuel injectors clogged or dirty flooding engine.
Clean fuel injectors, replace fuel filter and air filter, and see if the problem persists.
If it does ECT sensor is bad. If CMP sensor was bad, the vehicle won\'t start whether cold or hot. CKP senso and CMP sensor work together if either one fails, the vehicle won\'t start. Have the vehicle code scanned.
Apr 18, 2013 | 1999 Chevrolet Tracker
I have a 99 GMC suburban it has set for a few months its turning over but won't start I changed my spark plugs what else can I do.
with a glass.. like a shot glass poor half a shot into the intake. have a fire extinguisher handy and try starting it if it tries to start could be fuel pump or fuel filter
Jun 14, 2012 | 1999 GMC Suburban
Stalled on road, turns over but won't start.
you will need two people to test to see if you have a bad fuel pump. you will need a can of aerosol throttle body cleaner. open up the air filter casing and and make sure u do not squit any fluid on the MAF air flow sensor the bottle of cleaner sometimes has a red straw for further reach use this straw. the other person has to crank the engine and once the enine begins to turn over start squirting the fluid into the engine via the air filter tube. have plenty of trigger control becuse too much fluid might cause a back fire (so you might want to wear a clean glove) and too little fluid wont start the engine. if you get the enine to run for a brief second while squirting the chemical chances are that the fule pump is bad or the fuel filter is clogged. hope this helps
Aug 26, 2011 | 1994 Isuzu Rodeo
My 1995 Pontiac Bonneville will turn over and start but always dies. Already replaced fuel filter and the fuel pump seems to be working but the car will not stay started. Checked the gas release on fuel...
crank position sensor...if the engine will start and run for a second or two then it dies. If, however, you can press and hold the gas pedal slightly and keep the engine going, then I would suspect the IAC-idle air control valve. This can be cleaned with spray carb cleaner.
Oct 12, 2010 | 1995 Pontiac Bonneville
I seem to be having a simlar problem to several 406 owners, but none seems quite the same - any advice appreciated! 2002 406 L 90 HDI Remote key fob fails to work at all, even with new battery in fob....
Check for fuel and spark, For fuel it's as simple as removing your air filter and spraying carb cleaner while cranking. If still no start, then carefully remove a plug wire, insert screwdriver into wire (make sure you are not touching any metal or wood part of the screwdriver, you should be using a insulated plastic screwdriver) and crank the car while keeping the metal part of the screwdriver close to any metal on the car, within a quarter inch. This will narrow your problem to spark or fuel. If it starts while spraying the carb cleaner, then you have a problem in your fuel system, either a relay, bad pump or severely clogged filter.
Feb 18, 2010 | 2005 Peugeot 405
95 Chevy S-10 starting issues
If the engine is turning over and it still wont start try shooting a little starting fluid in the air cleaner to see if it will run .. if so your fuel pump is either bad or the fuel filter is getting dirty.. thanks and holler if you need more Jerry
May 11, 2009 | 1998 Chevrolet S-10 Pickup
Car will not start. please help.
ck the crank position sensor. It's on the front of ehgine at the crank pully. If there seems to be a fuel problem, ck the maf sensor. first sensor out of air cleaner. good luck
Apr 15, 2009 | 1993 Buick Century
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
298 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
