Question about Tomtom GO 720 GPS Receiver
New Batteries are required
Batteries
  • yadayada
    yadayada Jul 09, 2010
    ONLY TOMTOM HAS BATTERIES AND ONLY THEY Can install them.
    President:
  • 1,111 Answers
If you need a new battery, go HERE you wont find them any cheaper anywhere else..the cheaper ones are shipped from china but are the same as the ones in the usa if you dont mind waiting a little extra to get them,
if you need instructions on how to install it, just post back here...hopefully ill get the message.
bill
Posted on Jul 09, 2010
Where do I replace the battery for a cordless mouse that came with my MK300 keyboard
Q: Changing the batteries in my MK300 trnsp.gif 13634.1.0.jpg How do I change the batteries in my MK300?
Wireless Desktop MK300
Model Number:
Y-R0002 (Keyboard)
M-R0006 (Mouse)
trnsp.gif Battery Requirements:
Keyboard:
  • Requires 2 AAA alkaline batteries.
  • Expected battery life is up to 15 months.
Mouse:
  • Requires 2 AA alkaline batteries.
  • Expected battery life is up to 8 months.
Installing New Batteries
Install the batteries for your mouse and keyboard by making sure the batteries face the correct direction as shown in the image below.
Battery Replacement Tips
  • For best battery performance, always use quality alkaline batteries.
  • When replacing batteries, make sure the replacement batteries are new and are within the manufacturer's expiration date.
  • Do not mix old and new batteries.
  • Do not mix batteries of different brands.
  • Do not use rechargeable batteries in this product.
Jul 25, 2010 | Logitech Cordless Mouse
How to change battery in logitec wireless mouse
Installing New Battery
Install the batteries for your mouse by making sure the batteries face the correct direction as shown in the image below.
Go here if your mouse does not look like this. Select your model then look for changing batteries.
Good luck
Feb 18, 2010 | Logitech 9311570403 Mouse
Put new batteries in and it keeps powering down saying to change the batteries
Problem also could be with the type of batteries you're using. I purchased batteries at the dollar tree once and had that problem. When I purchase duracell batteries I don't have the issue. High drain devices like digital cameras require better batteries and cheap batteries like the ones from discount stores don't have the output required.
Oct 14, 2009 | Canon PowerShot A410 Digital Camera
Put new batteries in and can only take one picture then needs new batteries
Assuming that the new batteries are the correct type for the camera and they are fresh/fully charged, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 11, 2009 | Nikon COOLPIX L18 Digital Camera
Put in new batteris and nothing happens. They are
First, make sure that the "new" batteries have a full charge. If you don't have a meter to check them with, try using them to power something else. Also, if using rechargeable batteries, make sure that they are the correct type for the camera. NiCd batteries will not work well in a camera that calls for Ni-MH batteries.
If the batteries are OK, your problem may be due to corrosion on the battery connections inside the camera. Remove the batteries and wipe the camera contacts with a clean soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any specks that may have fallen into the battery compartment during cleaning, then clean and reinstall the batteries.
The above clears about 90% of power-up problems, and I hope it works for you. If not, your camera may have a more serious problem that requires repair by a camera shop or the manufacturer.
Aug 20, 2009 | Kodak EasyShare C663 Digital Camera
Not coming on with new batteries (have tried several new batteries)
this problem seems to be caused by a faulty battery protection switch fault, which is situated in the battery compartment.
May 28, 2009 | Olympus FE-110 Digital Camera
S40 Battery problem
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Mar 21, 2007 | Pentax Optio S50 Digital Camera
Choosing batteries
Your camera requires four AA size batteries. There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the Display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may vary based on the Alkaline batteries selected. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
Choosing Batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Tomtom GO 720 GPS Receiver Logo
160 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
