Question about Dewalt D28402 412" (115mm) Small Angle Grinder Paddle Switch w LockOn
I have a Dewalt Angle Grinder (4 1/2'' D28402) Checked that I have the O rings and don't see anything missing....don't know why but blade won't tighten down (unless I put the tightening wheel, wheel side out.
    Problem Solver:
  • 9 Answers
What do you mean wheel side out? It should look just like the picture, the nut side of the disc threads on first. Depending on what disc you want to put on you may need a spacer that goes on first and then a threaded washer on the outside.
Posted on Jul 09, 2010
How do I remove the gear from the gear housing assembly?
first grinding wheel > flange> safety cap > 4 screws >remove axis with drive shaft crown wheel > then 4 screws remove front with the armature if you must replace cone wheel and crown wheel. remove first the carbon brushes before take the armature out.
Dec 29, 2015 | Dewalt 4 1/2" Small Angle Grinder D28402
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
I have a dewalt 28402 grinder. I have replaced the pinion but I don't know how to get the helical gear out of the case to replace it. Any thoughts? Thanks Chris
You can buy the pinion gear as a seperate part but not the ring gear. Dewalt only sells the ring gear as a part of the gear case assembly, PN 623586-00.
Oct 28, 2010 | Dewalt D28402K Heavy Duty 4 - 1/2" Small...
Breaks support rings in all blades
are you using the proper inner blade flange?? that is the only thing that I can think of that would cause your problem
Jun 12, 2010 | Makita 9553NB 4" Angle Grinder
How do i change wheels
There usually is a locking pin that stops the wheel from turning. MAKE SURE YOU HAVE THIS UNIT UNPLUGGED!!! Press this button in while slowly rotating the wheel, once it engages the wheel will lock. With your wrench you can now take off the blade. It may have a left handed thread so going clockwise will loosen it.
Jun 06, 2010 | Dewalt 4 1/2" Small Angle Grinder D28402
Dewalt D28402 412" (115mm) Small Angle Grinder Paddle Switch w LockOn Logo
150 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
