Question about Panasonic PT-AE700U Multimedia Projector
My 5-year old Panasonic LCD projector (PT-AE700U). started to have a "blue" hue on the right side some months ago and recently it projecting "blue" pixels, visible on dark/black images. Lamp is one year old. Tried different HDMI cables and different inputs. Most likely coming from the LCD. Any fix or parts to replace?
  • js13md Jul 09, 2010
    fair enough
    However it is getting worse: more blue pixels everyday
  • 10,594 Answers
This is problem of light engine and blue lcd including its filters got defective and creating blue hue in image.
Need to replace complete light engine, it would be costly fix and nearest Panasonic service center will do the job.
Hope these info will help you.
Thanks.
Posted on Jul 08, 2010
  • 3 more comments
  • js13md Jul 08, 2010
    How much to replace the light engine?
  • Shahid Electronics
    Shahid Electronics Jul 08, 2010
    $1200 light engine plus labor is an estimate cost.
    Any ball park figure?
    Sorry I did not see your reply.
    Looks very expensive for a projector which I paid $1,500 5 years ago!.
    It is better to buy the new Panasonic PT4000 for $2,000. Any advice on this projector?
    Shahid Electronics Jul 09, 2010
    Thats correct, new projector is better option.
    You can keep using it with same problem until its lamp goes or sale it out in local tv repair shop.
MY PT-AE700U LCD PROJECTOR HAS A BLUE HAZE RUNNING VERTICALLY ON THE LEFT HALF OF THE PICTURE.
Open the upper cover remove screw back side of the projector
Remove LCD connector and clean with soft cloth and fix it again.
close the upper cover and then POWER ON if the problem exist then the blue LCD is faulty and need to be replaced.
(very carefully because the ribbon cables and connector of the LCD is very senstive)
Jan 22, 2011 | Panasonic PT-AE900U Multimedia Projector
My PTAE700U Panasonic projector has a blue area going down one side of the screen. What wouls cause this and how can I fix? Thanks, Pete
hi,
first check is complaint is with ur projector or the source u ar using. just connect any other input to ur projector and then test. if then also the problem remains, there is some problem in ur projector circuit board or lcd panel. if so u should consult the manufacturer for assistance.
ok
Dec 22, 2010 | Panasonic PT-AE700U Multimedia Projector
Blue hue on right side screen
Try changing your vga/dvi cable,or it could be colour decay.
May 07, 2010 | Panasonic PT-AE700U Multimedia Projector
I replaced the lamp on a Panasonic PT-LC80U thinking this will solve the yellow appereance, but it did work, it seems that there are not blues in the image. What Can I Do to solve the problem?
here are some probable causes..
This appears to be an older model (over 5 years old) and LCD projectors turn yellow with age. It's just what they do
However, if you are projecting a computer signal or a component signal, a short in the blue signal of the cable can cast yellow hues over your image. The hue will cover the entire image as if you are viewing the image "through rose (or in this case, lemon) colored glasses" so to speak. That's an easy fix.
Harder fixes: the blue LCD panel is weaking and/or gone bad.
If you have a round yellowish spot in the middle of your screen, the diffuser has been overheated and is "burnt".
Apr 08, 2010 | Panasonic PT-LC80U Multimedia Projector
Permanent blue hue down one side of screen PT ae700 panasonic replaced lamp made no differance tried compressed air no change please help
if the discoloration has a sharp pixelated edge, it may be the lcd panel. if the edge blends, it's the light filter (polarizer) that is burnt from excessive heat and dust. either one needs replacing.
Sep 09, 2009 | Panasonic PT-AE700U-EC HD Cinema Front...
I have a Panasonic LCD projector ( PT-AE700U) - I have had it for 4 years. Recently, I noticed it was projecting "blue" pixels on the bottom right hand side (small size maybe 3 x 8 inches) . Over the past...
your color calibration may be off. see if you can set the red green and blue settings all to "0" and see if that works. may want to refer to your manual and see how you can do that and also see if there is a auto calibration
Jan 23, 2009 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700U
may be a heat problem: check the psu unit for components getting too hot...use a laser thermometer and keep you fingers away from the psu ! other possible problem may be a bad capacitor or the thermal protection before the psu..but this would be a very uncommon problem.
Dec 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700U Multimedia Projector Logo
239 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
